diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
Anyone tried a thin slate armboard..? - Click HERE for Original Thread
owen
Thinking on my feet ;)
Owen
davidsrsb
Why, what advantage would it have?
Slate is not very well damped, it rings when tapped.
Hard to work - it tends to crumble after a while.
owen
I've not found it difficult to work at all - easy to drill (no hammer action using a carbide drill bit), and cut (using an old hacksaw blade). You can easily lap smooth flat surfaces on it using wet and dry sandpaper too - a quick wax provides protection from delamination, as does using washers to spread the clamping load of the bolts.
I've also found it to be acoustically fairly inert compared to grp and the like..
I'll be mounting a Mission 774 arm on a garrard 401 plinth - the 774 only has short mounting bolts, and I'd rather use a small piece of slate appropriately drilled as a mount than some PCB, or MDF (I have around 6mm to play with), especially as I dont have access to a machine shop for a sturdy metal mount...
Suggestions please..
Owen
sreten
if its an interface part to a plinth its not really an armboard.
Should glue onto the plinth using PVA wood glue.
I'd also use PVA as a gasket to the arm mounting parts.
Should be easy to get a nice finish.
Though I would say the ideal plate should have a hardness and
density somewhere between the arm mounting material and the
plinth material, maybe that slate does fulfil this criteria.
:) /sreten.
pinkmouse
Owen, if, you've got the materials, then go for it! I look forward to reading about your results.
davidsrsb
Slate is easy to cut and drill, that's why it was used for roof tiles, but spilts easily. It just does not seem "lossy" though.
analog_sa
Slate is about the best sounding material for an armboard IME. No, i wouldn't try it on a Linn but a constrained layer slate/aluminium seems to work very well on a non-suspended table.
owen
Slate it is then!
The TT (once complete) will be a 401 on a baltic birch ply plinth, slate armboard for a Mission 774 LC and my nice new denon 301 mk2 cart...
Probably into a phonoclone, and away we go!
Owen
Page generated in 0.02489709854126 seconds with 16 queries,
spending 0.00794911 doing MySQL queries and 0.01694798 doing PHP things.
