| workingonit |
Searching for info on the little ol' brown inductor in the bass control of my Acoustic 150 guitar head, specifically where I might find another or a suitable substitute. It tweaks out as follows:
1.85H, 127 ohms, "7197" stamped on case, potted in a brown epoxy, drum type (like a Fasel inductor in a wah pedal) @ 5/8" diameter. Any info is appreciated. |
| sreten |
your best bet is probably to have it rewound on the original core.
Not much call for 1.85H signal inductors in these modern times.
:) /sreten. |
| half_monkey |
did you manage to find a supplier in the end? i have a similar issue with one of the inductors from the graphic EQ in an Acoustic model 320 bass head. Problem is the rewinding idea went out the window when i broke the core taking it apart :-( So i need to buy a replacement. Vishay makes a part that looks like a plausible replacement (part no. TE3-Q4-TA-3H as far as i can work out from the datasheet), but i can't find anyone willing to sell it to me.
any suggestions for suppliers in (or that will ship to) the uk anyone? |
