diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Dayton quattro 12" + 240W amp - Click HERE for Original Thread
regal
I just finished a Quattro 12" + Dayton 240W plate amp ported home sub, the box 2. cu ft tuned to 30 hz. I am very happy with the performance of this. I mainly use it for music and it keeps up well with my mains which are driven by H/K's most powerful receiver. For less than a $300 investmen you can't beat this for music.
prerunnerv6
Sounds good. I've wondered about this combo myself.
If you are able to post pictures, please do.
xstephanx
ide tend to think that would give you a big peak at 30ish hz no? you should try stufing an old shirt into the port, listen to it sealed, you may like it more!
if i built a sub purely for music listening, it would be sealed...ironically, i prefer ported tower speakers for music listening.
and another request for pics
regal
Well I have a very big room so the 30 hz peak isn't a problem
xstephanx
id still try sealing it, but i try sealing everything hahahaha.
plus its fun to tinker.
but nice to see youve seen the fun involved in diy, before you know it youll have your own plans to make some new mains....then some power amps....then some pre amps.....before you knwo it your have a 7.1 channel consisting of massive fullrange towers each channel, each driven by a 400wmonoblock *drool*
regal
I built DIY mains for the bedroom, but for the living room I just can't find any plans with the efficiency I need. I have Infinity SM215's which are like 96db, I have never seen a DIY 3-way with this kind of sensitivity.
Page generated in 0.029295921325684 seconds with 16 queries,
spending 0.00919533 doing MySQL queries and 0.02010059 doing PHP things.
