| zafira1981 |
I have a LOT, i mean REALLY a lot of tubes. My father used to build amplifiers, rf transmitters and lot of stuff with tubes.
I want to "try" the tube sound, i've never heard a tube amp.
What can I do? how can I start?
maybe a pre-amp & an amp (low power) to test.
Thanks!!!
Jorge. |
| EC8010 |
| Valves need high voltages and that makes them dangerous. You really should cure yourself of this affliction before it becomes both expensive and dangerous. There are plenty of people here who would be happy to dispose of your valves properly... |
| zafira1981 |
| quote: | Originally posted by EC8010
Have you heard about Tesla Coils?
I'm pretty familiar with high voltage :rolleyes:
If I'm not dead yet, is because I know how to work with HV :)
thanks for the advice.
I cant sell the tubes, they're from my dad. If i sold one, he will kill me. But will be very happy to see me building a tube amp :) |
| Tweeker |
| quote: | Have you heard about Tesla Coils?
I'm pretty familiar with high voltage :rolleyes: |
Tesla Coils are even worse, I would be happy to dispose of any pulse capacitors, coil winding equipment, magnet wire, synchronous rotary or Marx Blast spark gaps, and tungsten electrodes you might have. ;)
Vacuum tubes (ones you dont care about sacrificing to Thor or Loki!) can also be used to drive Tesla Coils. |
| Tweeker |
| Another angle to approach this question from, what iron do you have hand, particularly output iron? |
| Giaime |
| quote: | Originally posted by zafira1981
Hello Jorge,
please post some info on the tubes you've got, I'll find something easy for you to start with, at only the expense of a couple of output pentodes ;)
But more important, do you have iron at hand? And if not, how easy would be for you to obtain some?
If you aren't so geek like us, for "iron" we mean power transformers, input transformers, output transformers, interstage transformers, autotransformers... everything that "transforms" is "iron" :D |
| Eli Duttman |
Do you have 6V6s, 6AQ5s, 12V6s, or 12AQ5s? All of these will work in an "El Cheapo". While it is a challenging 1st project, "El Cheapo" is an integrated amp; so, a preamp is not needed.
BTW, with minor tweaking, "El Cheapo" will work with 6BQ5/EL84s as the O/P tubes. |
| zafira1981 |
well I will take some time to write an excel with the tubes and cantity I have.
And about "irons", i didnt know that you call them that way, but at the first time i read it, i was sure you were talking about transformers :D so im a kind of nerd too :rolleyes:
My father is looking for the irons right now. he said he has lot of output irons and for the PSU too.
here is a pic of the box with the tubes:
| wa2ise |
| quote: | | I cant sell the tubes, they're from my dad. If i sold one, he will kill me. But will be very happy to see me building a tube amp |
Great! Be sure to ask for and get his supervision when messing around with high voltage circuits. If you haven't that experience yet.
Also he should be able to offer good advice on circuit layout and construction to improve success.
"Iron" for transformers, because the steel lams are mostly made of iron. And weigh like solid iron bricks.... |
| zafira1981 |
big & medium size list
43
77
42
43
47
75
78
1629
12AX4GTA
12Z3
1G3GTA/1B3GT
1K3
247 52-13
24A
25L6G
25Z5
25Z6GT
5AS4A
5U4GB
5U4GB
5Y3GT
6A3
6A7
6A8
6AU4GTA
6AX4
6AX4GTA
6BL7GT
6C5
6C6
6D6
6D6
6DE4
6DQ6B
6E5
6EM7
6J7
6J7
6K6GT/G
6K7G
6K7GT
6K8GT
6L7GT
6Q7
6Q7GT
6Q7GT
6SA7
6SJ7
6SL7GT
6SN7GT
6SN7GTB
6SN7GTB
6V6
6V66T
6V6GT
PF9
PH235
PM5
SYI56H |
| Tom Bavis |
| I think I spotted a pair of ECL82s in the box - they can make a stereo amp, as they are a dual tube - high gain triode and power pentode. You could do the same with 6AV6 or 6AT6 driving 6V6, or a 6SL7 dual triode driving both 6V6 channels... |
| Geek |
Did you miss some? I see a 6CB6A in the box, but not listed. |
| zafira1981 |
the list is only from big tubes. there are lot of small tubes that i didnt "catalogued"? yet.
tomorrow maybe i will take some time to write them.
I have 2 brand-new PHILLIPS 6A3. my father told me that he bought that tubes for a new high-fi amplifier but never made it. so maybe i can use them :rolleyes:
here a pic of 2 irons & the brand-new 6a3.
I think that the irons are for PSU, not output. maybe i will have to buy a couple.
| zafira1981 |
thats a good idea. maybe on vacations =D |
| jlsem |
A good sounding single ended amp would be 1/2 6SN7 => triode connected 6V6GT => 6A3. Choke load the 6SN7 and transformer couple the 6V6 to the 6A3. You won't be disappointed...
John |
| poobah |
Tweeker,
Have you heard a plasma tweeter???
:xeye: |
| poobah |
Zafira,
EC8010 is correct... send all your tubes to him... they are very dangerous.
:xeye: |
| Giaime |
| quote: | Originally posted by poobah
Zafira,
:xeye: |
No Rob, you're wrong. Big tubes like 6A3, 25L6, 6V6 are extremely harmful. If you leave them on a shelf or on a table, they could fall to the floor and broke in little pieces that could easily KILL children and pets. I'm the only one in the world to have a legal disposal facility, please send them to me to avoid dangers.
:smash:
(Nice, a 6A3 amp!) |
| edl |
That pair of 6A3's is a treasure! You can bulid a very good sounding pair of 3W class-A SE amp with them.
Tungsol 6A3 datasheet is attached.
Congrats' for your heirloom! :)
Regards, |
| Eli Duttman |
Zafira,
The 6A3s ARE a treasure. Except for the filament voltage, the 6A3 is identical to the 2A3. Good 2A3 circuits can be found all over the 'NET. There are 2 things to watch out for. Hum levels in a 6A3 are higher than those in a 2A3. Current regulated DC on the 6A3 filaments is the answer to hum. An 'A3 amp produces about 2.5 W. It has to be mated with speakers that are 97+ dB. efficient.
Jlsem,
Is there enough gain in the 6SN7/6V6 combo to achieve full power when driven by a CDP? An "integrated" amp makes sense to me as a 1st project. If more gain is needed, the 6J7s might be the "place" to get it. |
| jlsem |
| quote: | | If more gain is needed, the 6J7s might be the "place" to get it. |
Using Lundahl iron, the interstage can be configured as a 1:2 step-up if more gain is necessary.
John |
