| Netlist |
I found this broken SMD in a plotter board, in the regulator stage.
One side carries 40VDC, the other is connected to ground.
Rectifier->fuse->SMD->ground.
The fuse is broken as I measure a short across both leads of the device.
If you look carefully, you see a sign of a half sine wave and the letters M R. R might be B
As usual, any help is appreciated.
/Hugo |
| Netlist |
Onra,
thank you very much. Page bookmarked.
/Hugo :) |
| davidsrsb |
| These devices failsafe shorted |
