| Astro Power |
i want to build a box and to input the T\S data driver to the WINISD software.......
of this subwoofer
Link to Subwoofer data
but i dont what of the "SPL" is right to put in ths WINISD...?
i need to put the :
SPL@2.83V = 95.07dB
or
SPL@1W = 85.3dB
?? that is right?
thanks
tamir |
| coolkhoa |
| AFAIK SPL@2.83v should be the same as SPL@1W. You can dive into the math to prove that. It doesn't matter much to WinISD anyway, though; the "gain" graph is still valid, only the "SPL" graph is going to be different. Besides, you can change it later. :) |
| Astro Power |
it is matter........
i want to buy this subwoofer.....to highest SPL
or another subwoofer....
so i comper this subwoofer to other one...
i put the t\s data subwoofer to check ths loudest subwoofer...
so....if i put to the winisd the 85dB SPL@1M it is not loud for me..
and the secend subwoofer is stronger..
but if i put the SPL@2.83V 95dB it is very strong to me and it will be good.......
so what i need to put the winisd? 95db? or 85db?
tamir |
| coolkhoa |
| OK, I see. I can't give much more advice other than that you can increase amplifier power to compensate if you don't reach your SPL requirements. And manufacturers' data can often be off by significant margins (or SPL figures can be inflated intentionally). Better if you can measure them yourself. |
| Collo |
Hi there Astro
WinISD uses the SPL @ 1W @ 1m value. In your case, 85.3 is the correct one to use.
You can convert from one measure to the other with an equation that includes the resistance of the driver. See my "Driver parameter conversions" page for the details:
http://www.users.bigpond.com/bcolli...conversions.htm
If you wish to compare drivers, where one or more are described using the 2.83v (Voltage sensistivity) figure, convert their figures to the Power sensitivity measure. For DVC drivers make sure you are using the correct figure for the wiring option you are going to use (series or parallel connection)
regards
Collo |
| Astro Power |
thanks !!
tamir |
| micb |
Sensitivity reading like this should not be used to compair how loud subwoofer will be in real life when modeling in software.
There are so many ways to skew the numbers and then theres the argument than a fair few believe sensitivity numbers mean very little in the bass region... |
