diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
query on the PSU of a preamp - Click HERE for Original Thread
ray_ben
Hello all,
I DIY a tube preamp based on a circuit from a old magazine.
It based on a 6DJ8 and 12AU7. I have some query on the power supply circuit. The circuit is attached.
Are the 2 Zener diodes (27V and 12V) in the right positions or they should be swapped?
Do you know the purpose of these 2 diodes?
regards, Ray
hacknet
i think its alright..
the 12v zener is to prevent the mosfet from destruction when the Voltage across the gate and drain exceeds the maxium allowable.
the 27v zener is supposed to do the same for the regulator.
marconi
between gate and source you mean...
But you are correct for the rest.
Page generated in 0.016916036605835 seconds with 16 queries,
spending 0.00743365 doing MySQL queries and 0.00948238 doing PHP things.
Please support our sponsor.
