diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Silpads AND thermal grease - Click HERE for Original Thread
chipco3434
Does it make sense to use a small amount of thermal grease with Silpad 400's?
EC8010
No. The whole point of such pads is that they are conformal - or, to put it less technically, they squidge into all the crevices. Thermal grease isn't a good heat conductor, but it's better than air, so we use it if we suspect that there might otherwise be air.
chipco3434
I figured it would be also conformal to the light, subtle, woven texture of the Silpad...
EC8010
Agreed, there's a texture to the Silpad, but if you use one and then undo the device from it, you'll find that no texture remains.
Page generated in 0.02327299118042 seconds with 16 queries,
spending 0.00729465 doing MySQL queries and 0.01597834 doing PHP things.
Please support our sponsor.
