diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
Pages: 1 [2]
Carver Magnetic Field Power Amp -whazzit???? - Click HERE for Original Thread
anatech
Hi solderhead,
quote:
I seem to be missing how to adjust the B+ on the low (36VDC) and medium (74VDC) rails. If you could point that out I'd appreciate it.
Not adjustable. They are set by the mag coil in relation to the 124 VDC supply. Turn it down to 118 volts or there abouts. This voltage will tend to creep up over time.
And that is it in a nutshell. New motors always spin faster than teh old ones with bad brushes and bearings.
-Chris
solderhead
Just wanted to give an update on the PM-1.5 fan replacement:
The new OEM fan is definitely quieter than the original OEM fan in some respects, but louder in others, but the problem is easy enough to fix:
First, the new bearings mean no bearing noise. Quite an improvement!
Second, the new motor is made in China instead of Japan, and there are some subtle side effects of the Chinese manufacture that I had not anticipated. They make the idle speed of the fan quite a bit higher, and the fan quite a bit louder at idle:
Although the old and new motors share the exact same part number, the average DCR measurements are much higher with the new motors than with the old ones, presumably as the result of differences in wire gauge and winding methods in the motors. At the same voltage the new motors pull fewer mA than the originals, which means that they are less sensitive to the effects of the dropper resistors on the fan control board. As the amp idles the fans run at too high of a voltage and they are way to loud -- they sound like a Lockheed Constellation at takeoff!
Fixing the problem is simple. Just re-scale the voltage dividers on the fan control board to bring the operating voltage of the fan motor back into spec and the fans are nice and quiet at idle. They also speed up appropriately when the amp operates under load.
I re-scaled the dividers on my amp so that the amp with the new fan behaved like an amp that had a properly functioning original fan. The objective was to make the fan nice and quiet when the amp was at idle in the low setting (for home use), while maintaining the ability of the fan to speed-up appropriately under load. I also scaled the divider so that the fan moved a lot more air and was a lot louder under idle conditions at the high setting (for pro use), and increased speed appropriately under load. I also maintained the thermal switch that bypasses the voltage dropping resistors so that the fan will run at full voltage and full speed if the amp ever gets too warm. If and when that ever happens (I tested it by jumpering the thermal switch), the fan would move a LOT of of air, until the amp cools back down and the thermal switch opens again, allowing the fan to run at the speeds selected by the switch settings.
This way I was able to maintain adequate cooling of the amp under all conditions while keeping the noise level down to the original levels when the amp was new.
I hope this helps. If anyone needs help with this sort of fan project, drop me a line. I had to buy a box of these fans to get the right part, and now I have more than I need.
anatech
Hi Solderhead,
That is great that you got it all figured out. Good show!
It's been a while for me (replacing fans), but your description is what we used to see, except that the fan was quieter but only a little faster. I am a little concerned that you may have a current draw somewhere that caused the fans to turn faster.
I guess I should have measured the normal voltage across the original fans. Something I didn't consider since we did have the original parts at one time. It would have helped you out.
The new motors may also be more efficient and have less friction in the bearings. That would make them turn faster also.
-Chris
solderhead
quote:
Thanks for your help. You make a good point about the possibility of excess current draw at idle. That would cause the fans to spin much faster.
I was fortunate enough to have two amps to work on, one with a good fan and one with a bad one. I used the good amp for reference measurements of the voltages, and rescaled the fan motor's voltage divider to reach that endpoint.
The good news is that the amp is behaving well, and on the bench it puts out its rated power into a resistive load. The fan responds appropriately in testing. Although I guess there could be a current draw somewhere, I've never found it. The amp still has those old dual-element PSU caps on the low and mid rails. Those will be getting changed out very soon.
anatech
Hi solderhead,
Wow! :bigeyes:
That explains much. Replace them now, or as soon as possible. Personally I would recommend you not use the Carver until that time. Your voltage adjust may need to be redone.
Recently I worked on one where a dual cap leaked and blew. It was not a pretty sight and damage was high. Please avoid this situation.
-Chris
faustus
Carvers could not be used to drive mid or high only. That's probably why you blew them up. They would drive bass or full range all day.
anatech,
I'm most interested in getting a more complete description of your experience with locked-up commutators; most importantly, which models/years were subject to this failure mode?
I ask for selfish reasons: I am running two M-400t amps to biamp my speakers (horizontally).
Relevant note: earlier this year I had heard vague references to the same frequency spectrum limitation you describe, with the problem being limited to "early" Carver amps. I contacted Rolland Barr of Hi-Tech Audio, Ltd (a recognized Carver repair facility) to discuss... he had no experience with this type of failure, but opined that any of the "t" models are not "early" Carver designs. He further opined that a mf/hf-only signal would be fine driving an M-400t -- he advised me to do so without fear. He was so confident that he guaranteed to repair any resulting damage gratis.
So, I'm sure both you and Rolland are WAAAYYYYYY smarter and more experienced than I will ever be on this subject, and I'm not playing any sort of "one against the other" game. I just want to get as much information as I can on this particular subject since the health of my amplifiers may be in the balance.
anatech
Hi faustus,
I'm sorry, but I have to disagree with Rolland here. Some of the later models without commutation stages - yes. That would be the Lightstar most probably. I still wouldn't do this.
The commutator timing is set to a minimum hold up time. At high midrange and high frequencies, this would tend to keep the higher rail voltages engaged (commutators locked up). What he may be thinking is that high notes may be of a level lower than the trigger voltage. Therefore he is hoping the commutators are never triggered so they can not lock. Rest assured, at high power levels running mids or above only will definitely cause thermal runaway in these amps.
Consumer users do not normally do what you are doing, not with Carver amplifiers especially. Your M-400t's are not safe running mids up at higher levels. However, you may never trigger the higher supply voltage. The answer then becomes, how loud will you get these? The circuits are all subject to this limitation.
Therefore, you may or may not run into trouble. But Rolland is incorrect in thinking these newer amps are immune to this.
-Chris
faustus
anatech,
Your quick reply is greatly appreciated and I will refrain from high volume blasting until I have this issue sorted-out. I sure wish I could get a consensus opinion from two or more Carver repair experts regarding the commutator-induced failures.
With the hope of engaging you further on this matter, there are a couple of other details that I can offer. First, I have heard the problem described as a "rail switching logic error," which to me would imply that the logic error could be fixed or mitigated in later designs. Have you heard it described as a logic error?
Second, most of my listening is done at moderate volume, but I do push the amps hard on at least one CD per weekend. Thus, I have already run my dual M-400t rig at very high sustained power levels, with the power level LEDs on both the LF-only amp and the MF/HF-only amp near or at the maximum (top LED). Should my MF/HF amp have failed already, or does it take cumulative sessions to induce failure?
Many thanks for any additional commentary.
Cal Weldon
Faustus,
I believe anatech is a good person to listen to regarding Carver products. No one I know knows more about them.
anatech
Hi Cal,
Thanks. BTW, I can't think of any Jimmy Buffett song I can relate to. :D
Hi faustus,
No. It's an entirely analog circuit. The circuits will not respond fast enough for high frequencies to operate in time. Therefore the commutator must be timed to hold up for a short while to accommodate any high level high notes to avoid clipping them. So, if you continue to trigger the commutator on, it will not turn off before you trigger it again. This is not something that is even remotely easy to get around. If it was, Carver would have done so. They were on the cutting edge of this technology.
Could it be done today? Probably, and at greater cost. I'm not sure on this.
You are operating these in an area that would not be covered under warranty. Let's just say that your amps are getting hotter than they should be. At some point you may exceed the SOA on the output or driver transistors and "pop". Ex-amp. :hot: Luckily these normally shut down before killing the speakers. However, if the triac goes too, the amp will remain on at higher rail voltages than they were designed for. The destruction in that case would be extensive. Those mids and highs must be screaming!
If I were you, I would use a different amplifier for mid/high duty. I can't understand how your levels could be that high with normal program material in your home either.
The issue is thermal runaway due to higher than designed rail voltages being applied for long times across your output transistors. The commutators control the supplies switched to the output stage. I don't see how there could possibly be a disagreement here. If it makes you feel any better, I was the service manager of the Canadian Factory service center. My contacts at Carver were normally the engineers, not Carver's service department. They were not helpful at all. So, for what it's worth .....
-Chris
solderhead
I guess if anyone wanted to nitpick, "switching logic" could refer to either digital switching circuits of today, or analog switching circuits of yesteryear that used transistors or even vacuum tubes.
From what I've seen in the protection circuits of Carver amps, they do use transistors in a digital logic type circuit -- the transistors are switched all-on or all-off, just as the switching would take place in a digital computer. Granted, the "computer" in a Carver amp is an extremely simple circuit that only uses a few semiconductor devices and not a high density array of transistors on a CPU, but in both cases the transistors are switched on or off in a binary fashion. Binary signaling is what defines "digital" logic, and if an analog device is biased full-on or full-off, then its behaving as a digital switch. The protection circuits in a Carver amp can be considered to be fully "digital," just as vacuum tube computers that used binary signaling were functioning in a fully digital mode, and not amplifying a signal as analog devices.
With respect to commutator timing, my understanding of the circuits is that the triggering of commutator activation was a binary event that was defined by the signal envelope either exceeding or not exceeding a pre-defined threshold. Once activated, the duration of commutator activation was based on the time constant of an RC circuit. IIRC there were some TSBs from Carver that recommended changing the values of R or C in an attempt to modify the duration of commutation activation, and that these TSBs were specifically related to the types of commutation failures that Anatech had described. Chris, does any of this sound familiar to you?
I would have to agree that there really shouldn't be any opposite opinions about commutation failures among people that understand the Carver circuits. They seem to be well known among people who have serviced the amps, or have done their due diligence in reading about them. My guess would be that the warranty repair people who dealt with the Pro Series amps in bi-amping applications would have a better knowledge of the commutator problem than someone who is rebuilding consumer gear that's already long out of warranty. The later don't have the factory engineers to use as consultants.
solderhead
I think that if someone is running into commutation failures in home environment, they'd have to be actively bi-amping (with a higher than subwoofer crossover point) into an extremely inefficient speaker system, like a ribbon. By any chance are you somebody that has Amazing Loudspeakers and tries to run them at high volume levels? That could be a recipe for disaster.
anatech
Hi solderhead,
I tried to answer the question using the most common definitions of "logic". You are correct in that it is a type of analog logic, hard wired. Early commutators were "bang-bang" controllers. Later ones tracked the output voltage, keeping the VCE voltage approximately constant on the outputs above a certain level. But they could only track up to to a certain frequency and the top tier was still a "bang-bang" controlled event. Triggering this one is where your troubles really start in mid/high use.
No change orders or service notes were seen regarding any change in RC values for commutator timing. This could have been a USA thing, but the engineers I dealt with were of the opinion that the time constants were set up for the best compromise. I agree with them. This may have occurred very early in time with the cube product. They were still learning and developing the concept. I came in a little later when the bugs were mostly worked out. I still repaired an absolute ton of cubes though. Very few people were capable of repairing them. Patience I think made the difference. Hackers simply could not succeed here.
That was our biggest problem. Bridged no less. :rolleyes:
For the most part - yes. Pro people could not understand that these amps did put out the advertised power. Therefore they always used the lightest amps for ..... mid/high duty. I guess they can't read, nor do they understand English. We could never win with them.
-Chris
solderhead
That continues to be a problem to this day. IIRC the Amazings are 4R speakers, and may dip a bit lower. They're a pretty difficult load to drive.
I've heard quite a few folks claiming that its OK to bridge a moderate powered amp like an M-500t, and use it to drive the 4-ohm loads like the Amazings, just because Bob Carver did it at a trade show. Taking it all one step further, some of them are bi-amping.
IMO its hard to imagine a worse setup, and they're just asking for trouble -- Carver amps don't like low Z loads when they're running in bridged mode. When bridged they should be run at 8R and not anything less. Then you've got the commutation/thermal runaway issues if they're only driving HF signals. What kind of setup could be worse? Well, I guess they could try to do this sort of thing under the power of a small gas powered generator with a long extension cord...
anatech
Hi solderhead,
The long extension cord might save the day there by limiting the current. :xeye:
Amazings might dip to 2 or 3 ohms. They could be driven by the low impedance version of the PM 1.5, but not mid / highs only. Thinking about it, the amazing ribbon crosses over rather low, so this may be okay to do.
The problem wit ha Carver bridged into a low Z load are the demands placed on the AC supply. Over current protection would protect the amp just fine. So drooping AC is probably what would cause high current (followed by triac failure and all the fun that follows).
-Chris
imix500
This discussion has brought up a question- Stepping over to the Pro world for a minute, Clair Bros used Carvers for some time for biamping stage monitors and the like. (I forget the model numbers Carver made for them) Were the later, as in 10-15 years ago, Carver amps ok with mid/high duty?
faustus
quote:
Originally posted by Cal Weldon
Faustus,
Cal,
Thanks for the kind advice. No arguments from me on that one, anatech has convinced me to tread lightly.
faustus
quote:
solderhead,
Thank you for your participation, I sure appreciate everyone's advice. Let me give a couple of details...
I am not trying any craziness with Amazings, but I am trying to biamp a pair of relatively efficient ADS L-1290 speakers (8-Ohm, 300W, 91 db) that I recently acquired.
I started by driving them with a single M-400t, but I was interested in potential sonic improvements that biamping enables. Sure enough, adding a second M-400t in a biamped config did improve the sound at all volumes -- sounds cleaner, with a more composed content and/or less extraneous content.
But I definitely do not want to damage my Cubes!
faustus
anatech,
Thank you, sincerely, for your efforts to save my M-400t from disaster. I greatly value your extensive knowledge on these designs and appreciate you taking the time to share your experience.
You're right, I'm not going crazy with the volume on a normal basis -- The "super volume" test was a one-time event to test the new system config. In fact, maybe (obviously?) I'm not pushing the MF/HF amp hard enough to induce commutator failures? The crossover frequency is 500Hz, so the majority of the work is normally being shouldered by the LF amp. If I keep the volumes within reason, I might be able to maintain the system config, as is?
Christmas is approaching, so maybe I can justify just one more amp -- after all, this is practically an emergency.
anatech, thank you, again, for the solid technical details and advice.
midas
imix, you asked about clair bros using carver amps that ran not only lp2's (double 15" cone/ single 2" compression driver) but also ran s-4 foh speaker system. amp models were pm 1.5, pm1.5a, pm 1200 and pm 2.0 clair had trouble with middle two output transistors (which are the ones that are always on) blowing up on the original pm 1,5's carver/clair came up with the solution of parrallelling an xtra pair of transistors on the middle two-this became the pm1.5a and then the pm 1200 (all the same amp-475watts/8 ohms. the 2.0 was a different animal-roughly tha same power but only 11 pounds but changed to plastic case outputs. they worked fine for low/ hi applications day in day out for over 20 years...........midas
imix500
Midas, thanks for the info man. Obviously they were everywhere back in the day, but once in a while I still see them sent out with a package. Not from Clair of course, but a few smaller rental shops around nyc still have some.
m2003br
Hi Chris (anatech),
Before all, Happy new year to you and all in this forum.
Have you some experience with Carver PT1250 (or PM2.0t, wich appear to be the same)?
I donīt have the service manual for that, (I have only the schematics), and I need some advice about the exactly adjust of the duty-cycle of that PWM power supply.
Thanks in advance if you could help me.
Marcos
PS: The fan motors for PM1.5, PM1200, PT1250, etc... is exactly the same "MABUCHI" used in that "tunnel type" Hairdrayer
Tweekster
Ways to kill a Carver:
Run mids and or highs only (locks the commutators up).
-Chris
Chris,
What component damage do you typically see when a Carver amp is run for mids and highs only?
My father and I built a a home theater system quite a few years ago using a bi-amp front speaker system powered by a TFM-25 for the mids and highs, and a TFM-45 for the lows. The TFM-25 lost a channel a couple of years ago, and this may have been the problem.
-Win
Eva
Concerning the midrange and trebble usage, only oscilloscope can tell the truth about how much time the higher rails are active when they shouldn't. But anyway, if this happens, it should be noticed as abnormally high heating.
Consider that 1 milisecond SOA usually allows for 10 times the rated power dissipation of output devices, and SOA tends to become square above 100us. This holds as long as the duty cycle is kept low like in audio.
midas
marcos, if you e-mail me i can send you the section of the svc man you need. i can't e-mail any body yet! your talking about the carver that is 11lbs. right they can be a pain in the a55! imix 500 e-mail me i think we know eachother. don't ever underestimate clair! i've still seen some rigs go out with flame linear and sae (sparks and explodes!).....midas by the way, if any body needs carver fans i still have a dozen or so left. con air hair drier is close but draws a lot more current
toddyaudio
Its easy to see the result of commutator lockup by just monitoring the AC line input current of the amp, while varying the audio input frequency. For example: on a M400 cube driving 13v@8 ohms (~21 watts/ch) the line input current is about 3.8 amps@120vac, current stays steady up to about 5Khz then takes a sharp increase as you increase past that frequency. I measure about 5.6 amps of line current while putting out the same 13v@8 ohms at 15Khz. Almost 50% increase in current while putting out the same power. Yes, these amps do "burn up" more power at hi frequencies.
anatech
Hi Win,
Sorry for the delay. I've been "away" and will not be around that much.
Anyway, when a Carver is used in a manner that locks up the commutators, you will see a lot of overheated parts. Often the mid voltage rail capacitor may explode as well. You may even see a shorted triac, along with unusually high amounts of damage.
The protection circuits used in Carver amps are very good. Normal failures may only show one blown output (change them both) and that's all. If the triac shorts, expect heavy damage due to all the supplies going way up in voltage. It isn't very pretty. I've seen technicians do this (TV guys usually).
-Chris
anatech
Hi Eva,
Yes, for sure!
I normally monitor the second tiers for this. The third simply turns on full, and off full. The second tier should track the music signal within reason. High level, high frequencies will keep re triggering the commutator so that it never turns off. Locked up.
I can see you understand this concept very well. No surprise there. ;)
-Chris
Tweekster
Hi Win,
-Chris
Thanks Chris!
No need to apologize, I'm in no rush and appreciate the reply. :)
This amp has been on the shelf for awhile, so It'll be a project for my limited spare time. I want a working amp, but it's more for my education than anything.
A thorough cleaning and visual inspection shows no physically damaged components or brown areas on the PCB. I may have lucked out with only a blown output, we'll see.
This is the first Carver I've worked on, so I may hook up the scope just to watch the rails change. ;)
Richard Ellis
I have the Carver TFM-15 CB down here...occasionaly we have voltage sags...I once measured the wall AC & got 63 VAC.
So as I understand it if I happened to be running full power at a "sag" time with lots of HF content my amp would lock into the 'third' PS rail and go poof?
_________________________________________Rick.......
anatech
Hi Rick,
No.
Your TFM-15 uses a conventional power transformer. It does use the commutated supplies, so if you were to run 10 KHz into it and turn it up I think you would see it tend towards thermal runaway. Te zobel will not be happy with you and without that another effect would probably take over and end that amp's life. :D
-Chris
SyncTronX
quote:
Originally posted by crazygreek
I love my Carver amps!
I'm a Business and Electrical Engineering student at Lehigh University, and I have been acquiring broken Carver TFM amps over the past couple of years for repair.
I had been using my first TFM-15 amp for deejaying, although it just recently developed an issue (see http://www.diyaudio.com/forums/show...threadid=106952). I just recently repaired a TFM-15CB, which will be used for redundancy with my deejay equipment (repair guide here: http://www.lehigh.edu/~evb209/proje...r2/carver2.html) I also have two broken TFM-25's, which I have been trying to combine into one working unit. I'm sure DIYaudio.com will be a great for these and other projects!
Hey, I picked up a TFM-15CB, and put it in my system for a listen.
Sadly the high end sounded very "solid state". Yuuch, so it sits
on a shelf. I've been thinking of trying to upgrade it to sound better. But I'm novice tinkerer with solid state stuff.
Interestingly, I didn't realize you could take the bulbs out of
these meters....I guess that is what happened to the one
I got, cause they aren't lit.
Maybe we could start a baby carver improvement thread....
the TFM-15s ; )
anatech
Hi SyncTronX,
They can be improved, but I'd rather not have non-technicians running around replacing things without a very good idea what they are doing. Heck, most of the techs I've met hardly know what they are doing!
Honestly, this is still not a conventional amplifier. It does have higher supply voltages, but not as high as the TFM-45/55 types. This is a high power amplifier and things usually go very wrong, very quickly. There is more to "improving" an amplifier than sticking in some "better" components.
-Chris
componentbeggar
Jecy.lu took a picture of power supply section of Bob Carver's Magnetic Field Amplifier and sent it to me on JUN 30, 2008. Jecy told me there is nothing special with the audio amplifier section. He wanted me to study and do analysis about it. Please see the attached include schematics for detail:
http://tw.myblog.yahoo.com/componentbeggar/article?mid=863&prev=-1&next=862
Jecy.lu worked for a company in Taiwan to design audio amplifier and tuner 20 years before. His boss bought a Bob Carver's amplifier and had him to test it. I don't know how he got the schematics. He had already quit that company and be a sales to sell components.
SyncTronX
Hi SyncTronX,
-Chris
anatech, that is not a problem. I know my way around most any high power amp...actually highter power than most silicon amps.
Kind of a tube guy here. However, I be willing to learn some from
you npn, pnp guys. I even have me own bench. Nice little workstations or three for what ever should come up.
It is late here and have have a new president. Yeah.
Ok, so let me know what to do and I will do it.
Sync
anatech
Hi componentbeggar,
You're kidding - right?
Honestly, you are underestimating what is going on and have missed a fair chunk.
Now, this is from your link ...
quote:
Regarding the energy stored in the inductor ( L1 )
Ahhh, that's the output inductor from one channel of the power amplifier. It has zero to do with the power supply.
Your post illustrates exactly why we have trouble when other technicians get into these amps. They are confident that there is nothing tricky going on and assume they know how to deal with them. A hacked amp is the typical result. Even very simple circuits can be well design, elegant solutions to a tricky problem. You need to look more deeply into these if you ever hope to understand them.
No, I am not going to teach a course on these. I've probably posted enough information to explain these amps in enough detail to figure them out.
-Chris
anatech
Hi SyncTronX,
When I get to work on redoing an amplifier, it takes a while. There is no recipe that works on all amps. There are often some subtle things that you need to think about before they reveal their secrets.
If you are use to tube amps, that will help. These amps get tube type problems due to high voltages and high heat. The larger amps run at +/- 125 VDC. That's 250 VDC across the circuit, and we are dealing with solid state on consumer type PCBs.
I generally try to determine what operational problems exist first, and repair them. Once the amp is running to spec., I can figure out what deficiencies need to be addressed.
This is a normal amplifier really, so normal upgrade things apply. My definition of upgrading is probably different than most other people's ideas. The first step would be to match the first two differential pairs and tie them together thermally. After that, matching the predrivers forward between complimentary pairs would improve the sound and reduce the measured distortion. You can play with the resistors and caps after this. I normally replace capacitors that don't measure well. I use an HP LCR meter for this job and I'm watching the dissipation factor mostly.
Good luck in your endeavors with this. Let me know where you finish with it.
-Chris
Page generated in 0.13614797592163 seconds with 17 queries,
spending 0.01238227 doing MySQL queries and 0.12376571 doing PHP things.
Copyright Đ1999-2009 diyAudio.com
