diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
Advice on highest quality full range driver - Click HERE for Original Thread
deandob
I'm looking to build a full range system over the New Year holidays. I have been reading this forum and the other one at fullrangespeaker.com and have not been able to work out what would be the highest quality driver for my situation, as follows:
1) Lowest distortion. John Krutke did an excellent job measuring and comparing a number of lower price drivers. I have a pair of Tang-Band W3-871s as a computer speaker, which is a great speaker for the price. However I have not seen a similar comparison for the higher quality / price full range drivers
2) I will be using a sub below 100hz. I don't believe a full range driver can do the top end well and do the bottom end justice, the physics just don't allow it.
3) Happy to spend a couple of hundred dollars per driver to get the best.
4) Prefer a smaller driver, as I want to build bookshelf / small boxes. 3" - 5" preferred.
5) I listen to rock music mostly, however I dont expect this speaker to be driven to high SPLs, and it will be in a medium to large room.
6) Using a class-D amp (Hypex), so speed, dynamics, clarity and soundstage are important.
Any ideas? From what I can work out, the Jordan jx92 is best suited, however I'd be interested in comparisons with other equivalent drivers and what the differences in sound would be between these drivers.
Dean
ErikdeBest
Welcome to the endless search for the highest quality full range driver.
You already state you will be using the speaker mostly for rock - what kind of rock should I imagine? I've read comments that the Jordan is pretty good at voices/jazz, light things...but is messy at orchestra music, so probably won't do that good on the 'heavier kinds of rock' too.
Good luck
Erik
deandob
Thanks Erik,
Music is mostly light rock & some instrumental / voices.
I'm interested in subjective observations of differences in voice (tone/timbre), dynamics (speed), clarity (distortion) between the different high end full range drivers, and how they suit for near field and far field listening.
I can look up the objective differences between the drivers in their datasheets :D
Dean
Scottmoose
Lowther DX55. I do hope you're feeling rich though. If you can find any left, the limited edition Fostex FE166ES-R with its frightening magnet leaves most other things standing.
Cheaper and smaller: Fostex FE108ESigma could be a good bet, still cheaper, the latest version of their FE126E is making major waves at the moment. Providing you can find any that is...
Best
Scott
deandob
Hi Scott,
Thanks for the listing of recommeded drivers, which acted as a starting point for more research. It sounds like the DX55 is the driver to beat but costs big bucks.
Has anyone made a comparison between the DX55 and the Jordan Jx92?
Dean
sumacSK
Take a look also at veravox 5X. There is not much info about it on the net, but from what i've read, it should be one of the best.
Martin
deandob
Interesting that all the drivers recommended are ones that are rated for high dynamics, ie. lightweight cones, fast acceleration, strong magnets etc.
Can anyone comment on the sound differences between the Veravox 5X, Lowther DX55 and Jordan jx92 as these seem to be the shortlist?
Dean
soongsc
It's a pity companies don't publish large signal test results such as Klippel data. That would really help narrowing down selection.
Scottmoose
Yup. No less a luminary than Nelson Pass himself. Along with a dozen more too. This is from Nelson's First Watt site, and is refering to using power transconductance amplifiers (current-source amps) with full-range drivers, but it has good comparisons using voltage sources with these drivers too. Makes a good read. It might take a few seconds to load up though: it's a 2.5mb page.
Best
Scott
Landroval
How about the different Supravox 215 models? The 215-2000?
http://www.supravox.fr/les_hp.htm
Or Fostex F200A:
http://www.fostexinternational.com/.../F-Series.shtml
I've heard neither, but they seem to have some fans.
deandob
Thanks all,
Nelson's First Watt site has a good write up on the driver comparison.
Dean
Scottmoose
Sorry Dean -it might have helped if I'd actually remembered to post the link! I see you found it in the end though!
Cheers
Scott
deandob
From what I can work out after researching this for a while, for the smaller drivers the ranking for low distortion and decent treble:
1) Lowther DX55
2) Veravox 5X
3) Jordan jx92
The fostex range look good, but not quite in the class of the above drivers.
Next step is to study the enclosures, datasheets and costs to decide on a 4" - 6" driver that can be used for near field listening.
I have not been able to find much on the Veravox 5X, can anyone provide further pointers or experience with this driver?
Dean
sumacSK
Hi Dean,
I know that there has been a write-up about veravox 5X in one of the german diy magazines (with measurements, etc...) If you do a search for voravox 5x here, I'm sure you can find some folks who have scanned those pages, so they can send them to you...
Best of luck Martin
soongsc
quote:
1) Lowther DX55
2) Veravox 5X
3) Jordan jx92
Dean
Have you compared the Xmax of these drivers? The amount of volume the drivers can push is very critical for bass punch.
Scottmoose
True. Depends what enclosure you want to put them in too of course. For the moment, Nelson Pass' (again!) J-Lo looks to be one of the better DIY bets... providing you can get them through the door and have an understanding Other Half of course...
A monster TQWT like Terry Cain's Bigger Is Better box could also be viable, providing you've got the corners or a rear wall to load it. Although you aren't intending to go lower than 100Hz, you say your room is pretty big, and you want to rock, so this is one case I don't think an MLTL will be appropriate (and from an MLTL-nut like me, that's really saying something) as you'll want to be shifting as much air as possible.
Don't ignore the Lowther's cheaper PM45 and PM55 either. I haven't heard any comments about them, but they look good to me.
Best
Scott
deandob
Soongsc.
I agree. The Xmax comparisons are as follows:
DX55: +- 1mm. Wow this is small. Not going to move much air with this excursion.
5X: +- 1mm also. Looks like the 5x uses a similar design philosophy to the DX55.
jx92s: +-4.5mm. This driver will move a lot more air. I wonder if it will sound as dynamic/fast as the other 2, given their lightweight approach to cones which limits the Xmax.
Scott, as I want to build a more compact speaker (monitor), it looks like the Jordan will provide better bass in a smaller box compared to the other two and has a much lower Fo.
Dean
soongsc
Soongsc.
Dean
I'm not familiar with the DX55 and 5X, but if they have a larger cone area, that also needs to be taken into consideration. Some drivers spec their Xmax more conservatively and degrade gradually beyond Xmax. That's why I wish manufacturers could publish more large signal test data instead of just the traditional T/S parameters. The Klippel site provides some good insight in this aspect.
lithoc
Visaton B200 does sound fantastic to my ear very pronounce vocal
http://www.visaton.com/english/artikel/art_771_1_3.html
sumacSK
hi,
here: http://www.diyaudio.com/forums/show...ght=#post652252
you can find "almost" direct comparison between JX92S and 5X....
Martin
deandob
Lithoc,
Not sure a 8" woofer is going to reproduce decent treble. I'm looking for 6.5" and below, and want to build a smaller speaker with a sub.
Another interesting alternative is the Jordan JX53, which has better highs than the JX92 but obviously does not go down as low. The JX53 is being replaced with a new model that has a resonance frequency of 80Hz, so it may also be a candidate to be used with my sub (peerless 8" XLS with linkwitz transform).
I did a quick WinISD on the old JX53 using my tang band W3-871S in a 4L cabinet and the JX53 does slightly better on the bass. However with the preliminary specs on the new JX53 with lower Fo I thought it would go lower but the Q of the new driver is considerably smaller so it wont go down as low as the old driver.
Dean
deandob
Further investigation for the JX53 driver shows that it may be suited to my setup, as I have an active 100Hz high pass filter that will remove the bass energy from a smaller driver, allowing it to reproduce the treble with less distortion due to bass modulation.
The Jordan web site recommends this driver using a 200Hz high pass filter, however with a subwoofer anything greater than a 100Hz becomes directional. I'm hoping the new JX53 driver will go lower than the current version then it would be an ideal replacement for my tang bands.
Dean
sumacSK
As I see you want to use those speakers in bigger room for rock music... In this case JX53 won't work well with only sub... I want to second the B200 recommendation. I've read about direct comparison between B200 and JX92 (on decware forum-you can ask barfind) and B200 is said to be overal better (better bass, dinamics, much higher efficiency, also better top end!!! )
Martin
Colin
Dean
The replacement for the JX53 will operate to 110Hz in a 4 litre enclosure, 150Hz in a 1 litre sealed box. From a brief listen to an early version last year, it sounded very punchy, much more substantial in the 100-200Hz area than the JX53. Ted says there will be full spec on his website when the units are in the hands of distributors, in the next week or so.
soongsc
quote:
Originally posted by sumacSK
hi,
Martin
I kind of question whether that comparison was due to nonoptimized implementation of the JX92 or the definition of "live" is quite different that "live performance". Lots of people like speakers with certain longer decay and resonant characteristics. But then, optimization of full range drivers are kind of tricky directly pluging them into boxes normally do not yeild optimum results.
soongsc
Martin
I currently have a setup with the JX53 and JX125 crossed at around 450Hz. The bass is very good for all bass except the 1812 cannons. Low organ music really let you "feel" the low end. Rock music I cannot really comment because most recordings and live performances rely on electronic equipment, and they really differ from band to band.
tvi
Don't forget Bandor as an alternative to the Jordans, I love my 50mm modules.
The Hartley 220 MSG 25cm 20-22k, almost got a pair on ebay Aust with 24" and tweeter, but I was to cheap to go over AU$1,000.
The Visatons are available in Aust from sound labs group
regards
James
tvi
Hartley 10" Magnet
soongsc
Dean
Reading information from this site will give you a good idea what to look for regarding bass reproduction. The spreadsheat under "4 - Excursion-limited SPL Nomographs" is very usefull.
http://www.linkwitzlab.com/publications.htm
Scottmoose
Take Xmax with a pich of salt. Cone area, as mentioned, is a major factor, as is the enclosure type. A DX55 will stuggle to shift much air in some enclosures certainly, but stuffed into, say, a pair of MONSTER horns like the J-Lo or something of the ilk, cone excursion becomes less of an issue.
Subs directional from 100Hz up? Personally, I'd think that's very optimistic. 70Hz is about the limit of omni-directional frequencies. That's why Linn Kans (which really struggled below 100Hz) always sounded lousy with a single sub, but, when properly integrated, worked very well with a stereo pair of subs.
soongsc
Monster horns seem to rely on some resonance to achieve the low end, wouldn't that make the low end ring longer? That would really effect the "Punch quality" wouldn't it?
With the same air volume, I think the larger cone would perform better than a smaller cone in terms of punch capability.
deandob
8 hours sleep overnight and I come back to a page full of replies - especially when a few of the posters are in my time zone!
The new Jordan JX53 do sound interesting, although my ISD model of the preliminary specs dont show it doing as well down low compared to the old model (probably a mistake in the data). The old model has a reputation of burning out if overdriven, so hopefully the new model will be better in this regard, and using an active highpass filter will help.
The B200 is a little too big for my needs, but if a 8" paper speaker can do a good job reproducing the treble it is indeed a marvel.
Regarding subs, as I'm listening near field, if I cross over around 100Hz and have the bass unit very close nearby I dont have a problem with any slight directonality in the bass. Also with near field I dont need such high SPLs.
Bandor dont get the same rave reviews as the Jordans and it seems the Jordans have had ongoing development/tweaking.
The Hartley sure is a monster, but can't find any data about them.
Dean
one1speed
Interesting thread. It's nice to read about options beyond some of the usual suspects. I have to say that the Veravox looks really intriguing to me. Could be the next on my list.
With regards to the JX53, the current version. I read that it's not recommended to cross it much below 500hz. While it seems you could get away with it, I guess it doesn't have much body at in the upper bass / lower mids area.
Just thought I'd share. I'll be curious to hear what everyone thinks of the new JX53. Good luck with your search.
Dumbass
I think the JX92S would be an excellent choice, but I always feel that if you are willing to part with much dosh, you ought to actually listen to a pair before buying.
The new JX6 allegedly has an octave-lower resonance than the JX53 and could theoretically reach 100Hz, so don't rule it out either.
lithoc
Lithoc,
Dean
Dean,
I do agree with you that 2.1 is a very good setup. Initially I thought you were asking for single driver fullrange.
8" fullrange speaker at high frequency(>10khz) usually are very directional. :xeye:
IMHO, I prefer <4" mid/high & >8" woofer for 2.1 setup. crossover at 100hz.
deandob
lithoc,
Yes, a <4" driver with a 8" or larger sub at 100Hz looks to be the best setup for near field. The new Jordan JX6 would be worth hanging out for, especially if it does go lower by an octave (even if my preliminary WinISD model says it wont).
I currently use a 2.1 active highpass filter for a set of TangBand monitors with a lowpass Linkwitz transform for a small sub and get excellent results. Using this approach with the new Jordan should raise the performance bar even higher.
Dumbass, agreed, it would be good to listen before parting with the cash. I'm looking forward to initial reports.
One1speed, if you can dig up more info on the veravox or listening impressions, please post.
Dean
soongsc
How low the XO would be depends on listening levels.
With my experience with Jordan drivers, the later versions are always better than the earlier ones. If the cone area is increased, then it will have better low frequency driving capability. Got our fingers crossed.
Scottmoose
Bandors don't get the same rave reviews? True. Doesn't make them bad drivers though. They all come from the same person as I understand it. You see, the good lady who owns Bandor is, I believe, Ted Jordan's ex-wife, and the Bandor drivers are I suspect based upon some of his earlier designs which went with the divorce settlement. I hasten to add that I don't know that for certain, and anyone who knows better do correct me if I'm wrong.
As for larger cones performing better than smaller in the same air volume -sort of. Again, depends on the circumstances, and how the enclosure has been optimised. Assuming properly engineered and optimised enclosures (and drivers), I agree that the larger driver will tend to have more punch in the bass than a smaller one as it can shift more air. I think the DX55 etc strike a pretty good compromise.
Big horns relying on some resonance? Probably, I'm no expert on horns, so I'll leave better qualified people to comment on that and stick to my TL variations for the moment. That said, 99% of BLHs are actually QW loaded, not horn loaded at bass freqencies, and the smaller you go, the greater and higher up the QW loading tends to be. The Buschorn is a classic example -if you look at the measured response and frequency curves, it screams quarter wave loading -there's hardly the slightest hint of horn loading at all. I would tend to classify that as more of a resonance issue than that seen in larger enclosures, like the J-Lo for example. Then again, I'm just conjecturing here.
8" drivers can indeed do decent high treble -but it'll cost you. Lowther DX4 for example, or higher. The cheaper 8" units like the Fostex range and the cheaper Lowthers make a very good fist of it indeed, but if you're after treble quality as good as a high-end tweeter, you have to pay a whole lot more, or downsize to a slightly smaller driver like the DX55, a Fostex 6 1/2" unit etc.
Best
Scott
Colin
lithoc,
Don't rely on the simulations, particularly with some of Ted's drivers which can be a law unto themselves as the suspension is unusual. Ted himself uses computer sims so far then goes for the box and listen approach (I think he has something to say about it on his website). Although the JXR6 cone area hasn't significantly increased (as far as I know) from the specs I've seen, the xmax has increased considerably. (I've seen a pair 'breathing' at less than 10Hz).
Ref the Bandors, when I last heard several Bandor systems in the late 90s at a trade show, I thought the Jordans had the edge and they've probably been subject to more continuous development since. The JX53 got up to mk3 and the 6 is supposed to be a significantly better driver.
one1speed
lithoc,
Dean
I looked a bit online through Google and didn't find a whole lot, though did find a retailer in Canada, (for those of us in North America). Post #20 of this thread has a link that leads to a discussion of this driver. Hoping to do more research in the near future myself.
Page generated in 0.10297703742981 seconds with 17 queries,
spending 0.00913453 doing MySQL queries and 0.09384251 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
