diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Help me identify this Surface mount component - Click HERE for Original Thread
jives11
I posted this here in the hope that someone more familiar with surface mount components will be able to help. There is an active thread going in the digital section on the use of the Sony playstation One as a cheap and good sounding CD player. We are trying to understand the Audio circuit for tweaking purposes. Unfortunately we do not have a circuit diagram.
In this post you can see a strange dark gray rectangle with no legs but 6 solder points. It is marked red at each end, which I hope means something in the world of SMT
There is a picture and query here :
http://www.diyaudio.com/forums/show...4238#post784238
A picture is here :
http://www.diyaudio.com/forums/atta...tamp=1133994125
It does not look like a transistor , resistor, cap or opamp. The signal appears to pass through it i.e it's not open like a coupling cap. It measures no resistance on my admitidly poor Radio Shack analog meter. Both signals (R & L) appear to pass through this before emerging at the RCA outputs.
Any help would be much appreciated
Mick_F
Could it be something like a SMD ferrite bead??????
dhaen
Probably a filter.
example
Manufacturers have to be careful nowdays to conform to EMC regulations.
The answer to the next question is: Not one iota IMO.
peranders
Probably it's a feedthrough capacitor with ferrite (=filter) like many different products from Murata.
jives11
quote:
Originally posted by dhaen
The answer to the next question is: Not one iota IMO. [/B]
Thanks - but what was the question :)
dhaen
quote:
The usual follow up is: Will it sound any better if I remove / bypass it?
I_Forgot
The question BEFORE that follow-up should be "what is its purpose?"
Who knows, maybe electronics manufacturers pepper their PCBs with unnecessary stuff just to confuse amateurs and to prevent their competitors from copying their product.
I_F
Page generated in 0.025857925415039 seconds with 17 queries,
spending 0.00738931 doing MySQL queries and 0.01846862 doing PHP things.
