diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
How to wire 2 center tapped transformers - Click HERE for Original Thread
angsuman
Hi everyone,
I'm interested in getting the LM3875 briangt gainclone kit.
The project is budget motivated, and as a learning block for electronics.
However, all the dual secondaries toroidal transformers are too expensive for me. I'm curious that if i take 2 radioshack 25.2V CT 2.0A
transformers or 2 12.6V CT 3.0A transformers, if i can get away with that instead of dual secondaries. Also, how would i wire these transformers.
woody
You might check out www.apexjr.com he has a lot of surplus
transformers and caps at real good prices. Oh! shure you can
use 2 transformers but if this is one of your first projects I would
subjest just using a center tapped one less things to go wrong.
Page generated in 0.019989013671875 seconds with 17 queries,
spending 0.00945616 doing MySQL queries and 0.01053286 doing PHP things.
