diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
Mid-range Rings - Click HERE for Original Thread
FrankRoss
Any sources to buy or have made mid-range rings relatively cheap?
4 Bozak 6-1/2" midranges:
1/16" thick aluminum - 8" OD - 5 3/8" ID -- I can/will drill the mounting holes myself.
I've called several machine shops in the area, but claim not to have a plasma-cutter. A couple of other shops wayyyy out in the boonies want to charge between $45 and $100 PER ring - outrageous!
As a last and least desirable option, is there a bit that I can use on my router/circle jig that will cut through aluminum? I've Googled, but maybe I'm not searching on the right term.
Enzo
You might have better luck looking for milling rather than routing.
Page generated in 0.018070936203003 seconds with 16 queries,
spending 0.00783968 doing MySQL queries and 0.01023126 doing PHP things.
