| Alves |
Greetings.
I have cut in half a pair of Wireworld interconnects, in order to make two shorter pairs, using WBT-0108 connectors.
The problem is that on these coaxial cables the micro conductors are isolated. Thus, no signal passes to the WBT connectors.
How can I remove the isolation from the micro conductors in each end, so that the current flows?
Thanks and regards,
Alves |
| Alain Dupont |
Alves,
Use your soldering iron, to remove the insulation on the little wires...
I do it with a 50 watts iron, a piece of hard wood, good solder with resin core
and roll and press the cable under the iron ; it takes about 30 seconds to get it done...
Alain. |
| PauSim |
Hi Alves,
You could also use just the soldering iron (without solder) to melt the insulation, for that W108 copper-to-copper connection. Donīt forget to crimp the wires after.
Cheers |
| Alves |
Alain and Paulo, thank you very much for the tips. I will give it a try.
Yes, the WBT-108 are the crimp version. I have tried the solder version RCA WBT-101 with WBT solder and the results were not so good as just screwing (crimping) the wire directly to the WBT-108. Possibly, my solder technique is not the best...
Alves |
