diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
Laser unit used in Yamaha CDX-700 - Click HERE for Original Thread
Dumbledore
Hello everyone,
I wonder if someone could help me please?
I have a CDX-700 that is suffering from a weak laser. Does anyone know the part number for the unit, and if possible where one can be purchased in Europe?
Thanks.
Netlist
Have a look here:
http://www.diyaudio.com/forums/show...?threadid=59549
This appears to be valid for the CDX-700 too.
/Hugo :)
anatech
Hi Dumbledore,
Why do you think your laser is weak? Disc motors wear much more quickly.
If Yamaha has a service agent in your area, go there. There are adjustments to be done when replacing the head. You may be further ahead allowing the service agent to do the entire job. Do the motor too if you are doing the head.
-Chris
Netlist
If the calibration procedure is as tricky as in Pioneer equipment I wouldn't even think of DIY.
-=Hugo=-
anatech
Hi Hugo,
You have that right!! I have not ever seen another laser head where the diffraction grating needed to be adjusted - just to work! The early Yamaha's had a diffraction grating adjustment, but they would work ou of the box. That is until you touched the adjustment.
Actually, I got pretty good at doing both. Then there is the E-F balance adj. on the KSS-240A. Okay, I'll stop now.
-Chris
jean-paul
Too lazy to Google now but if it is the same laser as in CDX-99 I have one new in box for you. This one is a KCP1H.
Netlist
Perhaps one of those?
http://lamson.ftp4me.com/LAMSON%20A...ens/page_01.htm
/Hugo :)
Enzo
And if yuo will forgive me, did you clean the optics?
anatech
Hi Enzo,
Correct, always check the basics first.
-Chris
Page generated in 0.025119066238403 seconds with 17 queries,
spending 0.00858068 doing MySQL queries and 0.01653838 doing PHP things.
