diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
PCB for LM3886/LM3876/ LM4880 in INDIA - Click HERE for Original Thread
sivan_and
Anyone with a PCB for LM3886/LM3876/ LM4880 in INDIA..few each pls help
sagarverma
http://www.diyaudio.com/forums/show...5466&highlight=
HI,
THIS WAS THE THREAD I STARTED BOUT A PROB IN my amp.it has pcb as well as scheme(worked good but burned out a month back taking my Rs5000 pioneer woofer along with it).
your choice,use it(maybe i was at fault in using the amp properly).
gmphadte
The PCB -It will not be readily available.
U will have to make one for urself.
If u can laser print on a glossy photo paper then read here.
http://www.fullnet.com/u/tomg/gooteepc.htm
Other method is the good old one.
Draw the artwork using enamel paint on the copper and itch using ferric chloride. In this case go for 3886 as it's easy.
Want pcb layout, there will be hundreds in DIYAUDiO. I have one single sided design here.
Make urself one of this or make more and we will buy if it's good.
Gajanan Phadte
sagarverma
r u loking for pre fab pcb??
tell me also if u get one.(i would get different ones constructed)
for using toner transfer method(IN INDIA),u must take a look here:http://www.diyaudio.com/forums/show...t=&pagenumber=2
kuldeepsingh
hi fellows , i actually made DIY 4780 and 3886 pcbs. Here is the pics. If you are interested i can supply a few PCB on order.
yusuf
I am interested. Please let me know your contact details. Thanks
kuldeepsingh
Ya , i m from chennai, email id is kuldeep1@gmail.com
i have made 5 + 5 pcbs for my 4780 and 3886, made by laser toner transfer method. all are working excellent. If u wish i can mail u the pcb layout in pdf format so u can urself see. and i'll be charging Rs 200 for 4780 and Rs 100 for 3886 each PCB in case u are interested to buy it.
ziling
syber
Hi all,
I also need couple of pcb.
kuldeepsingh
visit http://www.diyaudio.com/forums/show...&threadid=99176
I have made a couple of LM4780 and LM3886 PCBs by normal laser toner transfer method (at home) and i offer them for sale in india.
http://www.geocities.com/cool_mechi/lm4780.htm
and
http://www.geocities.com/cool_mechi/lm3886.htm
I will charge 350 Rs per LM4780 PCb and 250 Rs per LM3886 PCB.
Since PCB are home made, it will be in very native form (i.e only PCB with copper tracks, no component layout, numbering etc).
Interested persons may contact me.
fibbrilator
I am also willing to fabricate and sell LM3886 PCB in small numbers. The PCB will be glass epoxy type, Home made using toner transfer method .I have constructed a couple of amps using this design and it sounds exceptionally clean, no hum etc.:cloud9:.The design is 100% star ground based. PCB size is roughly 85mm x 60mm .Shall Take a few photos and post when i get time. I will be charging 350 per PCB. If interested contact me at i_am_007@rediffmail.com
yusuf
COOL...may be you should post some pictures of your pcb here.
Yusuf
vikas456
Why the PCB so costly, when you can get the same in Bangalore at SP road for 40.00 Rs.
yusuf
quote:
Can you give some information about where do I get it for Rs.40.
Sometime back Suraj from OM electronics told me that they are making it, is the one you are referring to.
fibbrilator
Oh Man,
It would have saved me lot of pain and many many hours if knew it was available at 40 Rs earlier.Is it still available?:confused:
Thanks,
Gitesh
vikas456
Yes, its OM electronics, SP Road Bangalore, Guy at the counter told me that he was suppose to get consignment by first week of May,... but I am worried about the quality of the product and hence thought of buying PCB from one of you.
yusuf
oh okay, actually for reason unknown it is kept on getting delayed. I spoke to him 2 months back and when I checked last week, it was not ready.
If someone in Bangalore interested, we can get it done new compact design and fabrication. Its not very expensive. I am planning to do it but somehow time has been a factor.
I last week made subwoofer using chipamp and I am so encouraged with results that I plan to built few more amps.
fibbrilator
Thought i shall post some details of PCB fabricators in Bangalore.
1) Prototech: 7 days delivery , 3 PCB min Accepts gerbers via mail. Phone no:08023570296
2) P.C process: 10 days delivery ,Accepts gerbers via mail. Phone no:08028362596
Both the above companies are trust worthy, have done many PCB's with them. Call them and ask them to mail you the standard pricing.
Hope this info will be useful.
Thanks.
vikas456
Where in Bangalore is LM3886 available ?
yusuf
I could not find anywhere. OM Electronics told me he can arrange LM4780
fibbrilator
Tried vishal electronics and Amar radio? I have a couple of spare LM3886TF that i got from US.If you need mail me at I_am_007@rediffmail.com
vikas456
Email sent
fibbrilator
My home made lm3886 PCB
fibbrilator
7 of them for my 7 channel home theater AMP
fibbrilator
along with the heat sinks
kuldeepsingh
nice work, send pictures of finished amp..
ashok
How much does the LM4780 and LM3886 cost in Mumbai or Bangalore or Chennai ?
yusuf
I have one LM4780 in spare, most likely not going use it in near future. If you are in Bangalore, just pick it up.
Cheers!
Yusuf
http://blog.motiwala.com
sivan_and
Yusuf !! Can i have ur adress and telephone numbers? Even though am in Kerala I can arrange someone to pick up the boards...And don't hesitate to mention the cost !!
Sivanand
yusuf
Don't worry about the cost - I am just giving it away FREE to fellow DIYers, whoever can pick it up first.
Btw, it's not a board but just a single LM4780 IC. I will PM you with my contact details.
Cheers!
Yusuf
sivan_and
Huh Great help from a generous diy......But unfortunately am looking for the PCB's !!
kuldeepsingh
HI, i can send u one PCB for free. just mail me ur address.. i have made a few PCBs , you can check on my website
http://geocities.com/cool_mechi/audio
sivan_and
Thanks Kuldeep..u have mail !! but ur website ?
kuldeepsingh
above mentioned link is my website only. (sometimes this site has problems opening in firefox, better open it in IE). it is having some pictures of PCB and prototypes i have made
sivan_and
Ur right site works fully with IE.
Anyway congrats on your truly diy efforts...stage by stage ur experimenting and it really shows in the final pic .Keep up the diy !!
fibbrilator
Finally here is my completed amp photos :D
Amp with DVD player :
fibbrilator
:D . Back side of the amp showing the force cooled heat sinks and terminals.
fibbrilator
Sneak peek inside :
fibbrilator
Inside the amp. Looks bit messy but thats how star wiring looks like. Note the 2.5mm cross section wiring and the capacitor bank.
I was pretty happy with the results. no hum/hiss/ clicks . Only pure amplification. I did not put any pre amp stage/ tone controls as I only wanted it to do only amplification.
ashok
Aluminum extrusions from President Systems ?
mymindinside
Hi Yusuf
i would be very interested in the LM4780 IC if you still have it. can you email me at fdehlvi at gmail dot com if you are willing to give it to me...
thanks and kudos for keeping the diy spirit alive
love,light and peace
farhad
JPS
HI
Is there any source of LM3886 chip in india , preferably in Delhi
I have made a PCB but not getting the chip.
regards
ashok
Mumbai should have everything. You might need to serach. One of the earlier posts on another thread had some shop names.
Try searching for it.
I'm surprised that Delhi has no suppliers. Searching could be quite daunting with millions of tiny shops. I always get lost . On later trips I used to step into every shop one after another and mark them off on a list by shop number to make sure I do not step into the same shop again.
No point asking the shop keeper. I've never got any suggestions from any one of them. The standard reply was " we don't have ". Do you know who has it ? --"sorry don't know" ( then I get an indifferent look that says "now get lost we are busy " ).
Any Mumbai members with current info ?
Cheers.
ashok
I got a quote for about 200 bucks each for the LM3886 . But it's been about 5 weeks and I haven't seen a single piece yet ! Maybe the guy has got it mixed up with the LM4780 which I also asked for. I'll have to check it out. Has anyone actually bought one from their local ( Mumbai or Bangalore ) market ?
If we do have a real supplier he will show interest in larger quantities. Say a 100 minimum .
I'd suggest that we search for a reliable supplier who can get the part and then organise a group buy with a total minimum of 100 pieces . It will be much cheaper than getting it from abroad.
JPS
Hi Ashok
You have said it all. That is the reason I wanted exact shop number so that I can just go and buy the Chip. Can't move around
shop to shop.
regards
ashok
I forgot to add that the actual standard answer started with " How many pieces " , no matter what I wanted and even if they never sold that part .
If it was for a couple of pieces etc. , the answer was ' Sorry don't have'.
If it was a hundred or more then they would start calling other shops on the phone and give a much higher qote if they found a stockist ! Needless to say , we would be never be able to find out who had it !
linuxguru
I've bought single-unit quantities of the LM3886 from Chetan Electronics on S.P. Road in Bangalore for Rs.200/-. This was the isolated plastic tab version, not the metal tab version. The price may vary depending on availability.
YMMV, but the ST TDA7294 at Rs.85/- is a better deal for a gainclone. I've also got a PCB for the TDA7294 that is similar to the reference design in the ST datasheet. I'm planning a modified Class-G version, but it's very early in the design stage.
Page generated in 0.075611114501953 seconds with 17 queries,
spending 0.00813103 doing MySQL queries and 0.06748009 doing PHP things.
