I understand pinout is backwards, but that's not a big deal.
bigmike216
Anyone know? :)
wrenchone
Well, the "C" version of the Euro-fet is at the hgh end of the IDSS distribution in its device group, and the J201 will be on the low side of its device group, typically below 1ma. If you drop the 201 into a circuit designed to use the other FET, the bias will most likely be way off because of the difference in quiescent current. What is the circuit where you were planning to do this substitution?
Page generated in 0.019582033157349 seconds with 17 queries, spending 0.00969124 doing MySQL queries and 0.00989079 doing PHP things.
