| Stocker |
| I was just given an EPROM eraser which uses a 254nm lamp for the UV source... assuming the lamp is still good, is this wavelength suitable for PCB etching with the commonly available DIY chemistries? |
| Stocker |
Nobody?
this wavelength seems (on Google) to be mostly used for killing microscopic thingies and erasing EPROMS... but will it work for DIY PCB etching? |
| TwoSpoons |
| My workmate has tried the eraser lamps, but found plain old sunlight worked better. 254nm is too short, and too dangerous. Permanent damage threshold for your eyes is about 8 minutes! Short UV at that wavelength kills bacteria by crosslinking its DNA : ie causing massive genetic damage. |
| Stocker |
| Thanks for that. Maybe Ebay or a DIY water cleaner...;) |
| Devius |
| Positiv 20 works at 340-420 nm. |
| Stocker |
| ah, ok thanks but the bulb is specified as 254, not 354nm. |
| Devius |
ok... but that was my point. I just didn't concluded that in the post because it was obvious :P
I use a Philips TL20W/05, but that's just when there isn't enough sunlight because the sun gives me much better results than artificial lighting. |
