| Adams_Leo |
Hi all,
Due to my heat sinks,my friends and I have designed aleph-x integrated PCB layout.The board size is 310x102( mm ) and one channel's components in this board,please look into attached image file and give you suggestions.And your help will be highly appreciated.
Cheers.
Leo |
| analogair |
Looks great.
Which program did you guy's use.
I would sure like to make something similar.
But i'm not used to pcb design software :xeye:
perhaps you could post the files for the pcb |
| Carondimonio |
Hi Leo,
your layout looks good. I just have one remark: the space for the power resistors looks too small to me, 3W and 5W resistors are usually much bigger than what they look like on your board.
Bruno |
| Adams_Leo |
| quote: | Originally posted by analogair
Looks great.
We use the Prote 2004 DXP,If you need we can send the pcb fie to you.
Cheers
Leo |
| Adams_Leo |
| quote: | Originally posted by Carondimonio
Hi Leo,
Bruno |
Thanks for you suggestion,we have modified this.
Leo |
| analogair |
Leo, your pcb layout looks very nice.
Would it be possible to get the files. |
| Adams_Leo |
| Relayout the aleph-x 100W pcb,Would you advise for this? |
| gl |
Hi Adams_Leo,
This is a large board. Laying out a serious high current circuit is risky and can take more than one turn to get things right - even for an experienced PCB designer. I would recommend wiring your amp point-to-point on perf board. Then you can move things around easily if you run into problems.
I'm just trying to save you some money here. Board turns are expensive especially with big boards.
GL |
| Kari |
i've noticed that you use DXP for drawing the pcb. I'm also using DXP (Altium Designer 6.0). However i'm not able to find pcb footprints for heatsinks at all in the standard libraries. I see that you have them included in your board and i'm wondering if you could be so kind to send those libraries over?
Wonderful job on the layout!
Thx again,
Kari |
| Adams_Leo |
| quote: | Originally posted by gl
Hi Adams_Leo,
GL | Hi GL,thanks.
Leo| quote: | Originally posted by Kari
Thx again,
Kari |
Hi Kari,Please give your mail -box,I send the lib to you.
thanks
Leo |
| Kari |
Just use the email button at the bottom of this post.
Thx again,
Kari |
