| Buhl |
In the spirit of the earlier post: "Top ten ways to better an aleph" - I will try and launch this subject, something I think will be of interest for the many people that have build the excellent Pearl Riaa.
Here are my ideas - although they dont count to ten....
1. Using a battery for voltage ref. instead of Zener diode
2. oversizing the external PSU, using CLC og CRC filter, and bypassing all caps (also the onboard) with small polyprops. External PSU located far from the RIAA it self.
3. More BIAS to the 2SK170, by lowering the source rsistor from 22 to 18 ohms ?
4. Bigger/better caps for output coupling ?
5. Copper shielding of the whole circuit
Thats only five - any other ideas / suggestions ?
Cheers !
Buhl |
| Panelhead |
1. Match up the current for the 2SK170 and the 389. All mine were all over the place straight from the Q pack.
2. I used mumetal shielding for the box.
3. Blackgate NX work great on the output
4. Better signal wiring. First used DNM wire, replaced with XLO with very positive results.
5. After feeding it with a CLC, try raising the input voltage. The energy stored in those three 10K caps can juice up the circuit a little.
6. If using a LO MC, make a copy of the first gain stage to amplify. Tried a transformer, and it was not very good. Too much input capacitance with the four 2SK170's.
George |
| tschrama |
| Skip the 22 Ohm resistors |
| Stefano |
| Use LC filtering! |
| thorstenlarsen |
Hi !
Here is an idea I got from an article by Jean Hiraga:
Try lowering the voltage over the FETs ( and increase it over the bipolar ). You can go as low as around 3 volts. This reduces Igx , excesive gate current. It worked well for me in a Monster. Gave a more natural sound with more wood in wood instruments , more brass in the brass etc.
Thorsten ( another one ) |
| steenoe |
Hans, I dont even get the idea of bettering the Pearl!! I have nothing to complain about:smash: The sound of the Pearl is just marvellous:) About better supply filtering: there is no supply noise whatsoever! So what would you make better?? CRC CLC whatever, if there is no noise at all, what difference would it make? If you have trouble with the Pearl, its probably in your grounding scheme:xeye: I dont think you can easily better this one:) Its about the most silent RIAA I have ever heard:) The soundstage is just outragous:) No humm, no hiss, no noise, if its connected in the right way :) :) I just love the sound of the Pearl!
Steen:cool:
Edit: You cant just drop the source resistor!! Your J-fets wont have the right working point!! |
| audiotux |
Hi Steen ,
can you please share a little bit about the other Single-Stage
Phono -Amp in the other Thread ?
Jürgen |
| steenoe |
Hi Jurgen:) Its you again:D I will post some more in the RIAA for BoZ thread;) Ok with you?:)
Steen:cool: |
| audiotux |
Yes , shure !
Jürgen |
| steenoe |
Steen:cool: |
| steenoe |
| Wow that post came out in double:D :D :D |
| Panelhead |
[QUOTE]Originally posted by steenoe
[B]Hans, I dont even get the idea of bettering the Pearl!! I have nothing to complain about :smash: The sound of the Pearl is just marvellous:) I just love the sound of the Pearl!
Why didn't you say this earlier, I have built a phonoclone, Borebely 419, and an Onoclone. All to better my two year old Pearl. Could have spent all this time playing records.
Seriously though, if one betters the Pearl I will give a blow by blow. Too early to say now. The Borbely is just finishing, and the Ono needs a couple chassis.
I found the Pearl a little flat dynamically at first. But the output caps, signal wiring, and step up all three were less than optimal. It is excellent sounding now. Might have wasted a lot of time and money.
George |
| audiotux |
Yes please go on , i like to hear good news from you !
And nice that you cook Jamie Oliver style !
Jürgen |
| steenoe |
| quote: | | Why didn't you say this earlier | I dont know:smash: I just know that the Pearl is right for me:) I dont think the Phonoclone or something like that will be as good as the Pearl:) I can only think of one thing with the Pearl, and thats the gain, that possibly wont be good enough for all systems?? Its good for mine though;) I just made the Pearl as it is supposed to be made;) I have heard those things about missing dynamics before, but I cant agree to that! The Pearl is more or less perfect in my system at least! The sound of it is just great:) No doubt:)
Steen:cool: |
| steenoe |
| quote: | | Yes please go on , i like to hear good news from you ! |
| quote: | | And nice that you cook Jamie Oliver style ! | Jurgen, I just bought the cookbook "Jamies Italy":)
It doesnt get any better than that:D I just love the Italian style of cooking:) I am sure my family will love my cooking too:D :D
Steen:cool:
Jurgen, send me some sauerkraut, some day:D |
| choky |
| quote: | Originally posted by steenoe
Steen:cool: | what spks you have? |
| audiotux |
Yes steen i send you the Sauerkraut , and you can send me
nice PCBs !
Jürgen |
| steenoe |
Here you go, Choky:) A pair of those pesky Response clones;) I did put in some other screws though:D :D They are veneered with Elmtree! What a work:cannotbe: :cannotbe:
Steen.:cool:
Ps I have a pair of Proac s1 clones also:cool: And a pair of Corals, now that I am listing anyways:D
The S1's are the best:cool: :cool: |
| steenoe |
| quote: | | Yes steen i send you the Sauerkraut , and you can send me | Ok Jurgen , we better take this offline:cool:
Steen:) |
| choky |
I like elmtree ;)
I use to have half of hmmmmmmm- log? on top of my monitor-hehe -as I say -for screening purposes.......
will you try some oneways some day? |
| steenoe |
| quote: | | will you try some oneways some day? | Yep, I have a pair of Coral Flat6 that is supposed to be driven by the darn F2 I am working on!! I am sure it will play in short time:smash: :smash:
Steen:cool: |
| Buhl |
Hello Steen - and others....
Its Ok that you don’t have anything to complain about - neither do I, BUT - I have built 3 Pearls in the last couple of months, and the all sounded different from each other, so there are definitely some parameters that you can change, and it will affect the sound, maybe to your liking, maybe not.
Supply noise - I have a inefficient set of Proac clones, just like you - on them, there are almost no noise - switching to my Snell E II (+5dB in sensitivity)- there are definitely noise to be heard, and more noise than ex. with the Ono. Hence, I build a version with an even more overkill PSU, with 80000 uF in the PSU (plus the 43000 uF on board) - and added two extra RC filters - the result was even less noise, but more pronounced was the reproduction of space - the room 'grew' in some way. It is quiet, but ex. the Ono is quieter......but its ok for me.
I have also builded one in a wooden box, and one in a metal box - there weren’t more noise in the wooden one, but the "metal" had more bass, and more pronounced bass - why I don’t know.
Have built it with and without battery, and there were no obvious difference in sound - except its easy to hear when the battery runs down, and that happens once a month......
I don’t have any trouble with it - builded it just like Wayne in his article - have tried a lot of different groundings - about 3 hours with the soldering iron, and the RIAA turned on, to find the grounding that made the least noise - and it was the "wayne way".
I don’t think that you can say what is best for you, if you have not heard them all - i have not heard them all, therefore I experiment.
I wont just drop the source resistors, don’t worry ;- ) - but I recall that nelson suggested that one could lower the value to 18 ohms, given that the devices was matched well enough.
Cheers !
Buhl |
| tschrama |
| Allthough dependent or your specific set of 2Sk170's , but you won't run in to problem if you drop the source resistors. The bias point will change offcourse but there is room enough for that. Transductance will be somewhat higher (good for MC) en noise will be somewhat lower (again good for MC) .. THD won't change much , since this is primairily set but the output stage. |
| Buhl |
Hello tschrama
Ok - that must be tried - but what do you mean with "your specific set of 2Sk170's" - all my three kits are from promitheus - 2sk170BL - is it the type - BL or not, or the matching ?
Cheers !
Buhl |
| Panelhead |
The 2SK170 came in three grades, GR,BL, and V. The differences are in "on resistance" or current flow. If you replace the BL with V, the current maybe too high. The current through GR would be low in this circuit. Tied straight to ground they would run along fine.
The 170's are low current fets. No resistors will also make matching them up more critical.
George |
| steenoe |
Hans, after reading your last post, I realise that I might have been to fast, out of the gates;) I never heard a better RIAA than the Pearl (on my system), thats why I will think twice about modding on it. Your findings tells us, that maybe something could be gained anyway:)
If you didn't read them yet, here is a couple of nice articles about J-fets. They say a lot about biaspoint and Idss limiting via the source resistor and so on. "J-fet's, the new frontiers" are the ones.
Before anyone starts to fiddle with the resistor values, remember that the SK170's in Pass's Q-pack's were not matched. (Or so I was told at least)
Steen:)
http://www.borbelyaudio.com/special_articles.asp |
| thorstenlarsen |
Hi !
Now this thread has come out of the sauerkraut and back to the technical. So I´ll try again. ;)
Any experiences or comments ? :wave2:
| Buhl |
| quote: | Originally posted by thorstenlarsen
Hi !
Hello Thorsten
Sorry if it was me that brought the sauerkraut into this thread - bu, having chosen Computer Science, instead of EE - I lack very fundamental knowledge about electronics.....
How - do you lower the voltage over the Jfets, and how do you do that ? By higher value of the source resistors ?
And the bipolars - I expect those to be the N-channel (eg. ZTX450) that are used as cascoding and regulating devices - how do you raise the voltage here - by lovering their collector value ?
I sorry, but you have to "cut this one out in cardboard" to anglophile a well known danish expression ;-)
Cheers !
Buhl |
| tschrama |
| Like Thorsten, I would recommend lower the JFETs voltage too, it seems to lower noise a bit.. |
| AuroraB |
Now... I have 4 PCBs for Ono an 2 for a Pearl.....for me and my brothers....( we probably will have to draw tickets when I'm all done..)
- and I have a bucket of SK170 GR.. judging from the above, I wil do fine by shorting the source resistors... but wouldn't lowering them so -say 1-5 ohms instead help the balancing between them..?? |
| MRupp |
| quote: | | "Try lowering the voltage over the FETs ..." |
Thorsten,
I found te following information in an article from Klaus Boehning detailing his phono pre design, at http://www.klaus-boening.de/html/lab_page.html - check the chapter Determining the lower limit of UDS . Some other references tend to also prefer a higher VDS for the common source transistor but I cannot really say what is better.
Btw., where can I find the Hiraga article, please? |
| thorstenlarsen |
The article was about a hybrid amplifier called " le Passific ". Two stages with j-fet/bjt cascode input differential driving two el84 push-pull outputs. I read a photo-copy of the article around 12 years ago. I think it was from "l`Audiophile".
The decision to lower the fet-voltage was made on subjective grounds. The lower gate leakage current was mentioned as a possible explanation for the better sound quality.
I tried it out on a "Monster amp" together with a friend, and we came to the same conclusion as Jean Hiraga.
To Buhl: On the Pearl schematics at passdiy.com, you can see two voltage-dividers each with two 10 kOhm resistors. The middle points connected to bases of bjt´s of the cascodes. To decrease the voltage over the fet, you just have to decrease the value of the lower resistor. For listening tests, just solder another over the existing one. Remember that a new solder-joint takes around 15 minutes of playing to burn in.
Just try it out. But let us know what you think.
Thorsten
( another one ) :) |
| steenoe |
| quote: | | Now this thread has come out of the sauerkraut and back to the technical. | Hans, I am sorry to have caused disruption on your thread! I see now that my post didnt have the impact, it was supposed to, at all! I did read my first post again, and didnt find it expressed, what I meant it to! The tone was too harsh, no matter how I try to turn it:whazzat: I am sorry for that:) The sauerkraut is all mine, Hans;) I will try to contribute in a more polite and hopefully enlightening manner for the future:)
Steen:cool: |
