diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Transistor specialist needed - Click HERE for Original Thread
portlandlay
Ok I am not too good (bad) with transistor amps and I want to resurrect my Sugden A21 series II amp.
When I bought this old amp the output transistors did not match and I want to right this poor beast before I put new PS caps in and fire it up.
The not to unusual problems is the original power transistor is a BDY38 and these are not available. I emailed Sugden and I was told that a TIP 35c or MJE2955 could be used.
Now I am confused. Totally. The original is an NPN type in a T0-3 case and while the TIP35C is NPN the MJE2955 is PNP and neither is T0-3 form. Now a MJ2955 is the right case but it is still PNP and the Sugden gentleman said that "PNP is Spec"? But wait the original iBDY38 is NPN :xeye: Then I read about the MJ1500X's being a good replacement in the JLH amps. HELP ME!
Perhaps someone is familiar with this Class A amp and I chose to put this request in this forum after reading about Nelson Pass working on the JLH (PLH).
Stephen
Netlist
Stephen,
In the old days we would have replaced a BDY38 with 2N3055 which is also TO3.
These are however outdated transistors and today I'd probably try something like MJ15xxx. Other members, more familiar with that amp will probably point you to a more precise device.
/Hugo :)
PB2
How many BDY38s do you need?
Do you know who manufactured the originals?
Phillips or ?
Was it common for them to fail in this amp?
Pete B.
portlandlay
Only one is missing. It does not have a manufactuer designation on the outside of the can it just says BDY38 and under that 3K50.
The can has a little more depth (thicker) than other T0-3 types I have seen.
I do not know too much about the transistors in this amp failing but it is from the early 70's so... Perhaps bad caps caused it?
PB2
I have a friend who can get NOS semis but that's a small quantity and replacements would probably be from much newer stock so you'd probably want to replace all of them.
Pete B.
anatech
Hi portlandlay,
I think you'd be further ahead picking up some MJ15022's, a set. At least the amp has new stock. You may need to kill some oscillation, but it may anyway (oscillate) if supply and supply decoupling caps are bad.
-Chris
portlandlay
Hey that would be great. If you can help I would appreciate it. There are only four total. I would take two sets for the future.
I still would like to know what others would be good replacements since the Sugden guy really confused me...
PB2
Do you have a schematic and complete specs on the BDY38?
Do you know if parts were matched or selected?
I'd suggest, over the 2N3055A, the 2N3772 or even better 2N3773 which is a preferred part at On Semi.
But I have no experience with that amp.
These parts originated around the same time as the BDY38 but have much better SOA characteristics, and are probably better in every other way.
I've done many substitutions without problems, but I usually choose good designs to work with. One with marginal stability could easily oscillate with substituted parts.
Pete B.
portlandlay
I am not sure if the transistors were matched or selected but I do not think they were.
The schematic can be found in here http://www.tcaas.btinternet.co.uk/ navigate to "other class A amplifiers" and then to the Sugden 10w.
The ouput stage is a bit different but that can be found on page 6 of the associated article found at the same web address.
anatech
Hi PB2,
2N3773 is a much better sub. That's the one to use. I didn't know it was still in the catalog.
Matching them is always a good idea, this will improve current sharing. When the amp was build, the devices would have been close from the manufacturer anyway.
-Chris
PB2
Hi Chris,
That's a good point, there's a chance that parts from the same lot came from the same wafer where the silicon process is then identical. Parts from the same wafer should be nearly clones of one another.
Pete B.
portlandlay
Thanks all for the ideas. I am going to order a few different sets. First the cheap 2n3055's to get it up and running. These should be pretty close to the BDY38's. I will get some MJ15003's and then some 2N3773's as well.
Thanks again and when it is up and running with these and new PS caps I will let you all know how it goes.
anatech
Hi portlandlay,
The only thing to really watch is the speed of the outputs. Most are fast now and that's why I really like Pete's suggestion to use 2N3773's.
Replace the electrolytics on the boards before you start. Some of the film caps might be bad by now too. I would not use 2N3055's. Waste of time unless you have them. Be aware the original spec for collector emitter breakdown voltage is 60V, not 100V as many manuals state. You would need 2N3055H labled parts.
-Chris
portlandlay
I think that the original BDY38 had a lower collector - emitter breakdown voltage (40 I think).
Since I am not at all a transistor educated guy which are the newer transistors that are too fast.
Also what would be the difference between the 2n3773 and Mj15003?
Stephen
anatech
Hi Stephen,
Plug the different numbers in here to see the specs. I could just tell you, but this will allow you to look up the information yourself in the future. Just ask if you are unclear about anything.
-Chris
portlandlay
Thanks - I printed out each of the data sheets. They are pretty similar and perhaps either is a good replacement. Both are certainly much better than the original BDY38.
PB2
Hi Stephen,
The MJs are excellent parts but they're probably faster than the BDY38s, really even the 2N3773 is probably faster in todays technology but I doubt that you'll have a problem.
You might note the thermal resistance from the die to the package, which with all things equal is an indicator of die size. The 2N3773 is a bigger part than the 2N3055 which is also indicated by the higher power rating. It being high voltage will keep them out of secondary breakdown.
They're a preferred part indicating that they're going to keep on making them, probably because they're a superior substitute for so many of the older NPN TO3 devices. The larger die makes them slower which should offset the newer technology to some extent.
It is interesting that at a glance it might look like the 2N3055 has better hFE but you might notice that they're rated at different collector currents. The 3773 is tighter across temperature and higher across the more important 0 to 10 amp range as can be seen from the curves.
Matching is not an issue given that this is a quasi complementary design, but you probably don't want to risk any of the other parts failing and that's a good reason to change them all.
Pete B.
portlandlay
Just as you were writing this I was filling my order for 4 2N3773's.
I did notice (newbie here) that it is a little hard to make fair comparisons at a glance as many of the data sheets do quote specs apples to oranges or at least tangerines to oranges.
Thanks a million all for the replies. I have also order 4 new PS caps and a couple of other caps that look suspect. I will put this together and then ask more questions about setting bias.
The web page I quoted earlier does have a quick procedure - will the new transistors change this?
Stephen
anatech
Hi Stephen,
No, the instructions refer to the circuit. 2N3773's are the way to go here.
-Chris
Page generated in 0.048321962356567 seconds with 17 queries,
spending 0.00885105 doing MySQL queries and 0.03947091 doing PHP things.
