diyAudio.com diyAudio Forums Archive > Top > Market Place > Trading Post
Wanted: Dac pcb for tda1541a (non tube based) - Click HERE for Original Thread
ash_dac
Does anyone have a nice DAC pcb for tda1541a (non tube)?
I have looked on the net, and most of the 'well-known' tda1541a pcbs have been discontinued.
Kind regards,
Ashley.
Cobra2
-without the DAC & reciever-chip, + analog(discrete) IV stage.
(will take new picture later)
Arne K
Anything fun for trade?
ash_dac
Arne K,
erm not really got much of equivalent value:-
-a used untested Philips cdpro mechanism
-a tda1543 dac board
-tda1541a dac
-tda1543's (7)
-opa627AP (X5)
Where did you get the pcb from?
Kind regards,
Ashley.
Cobra2
CD-Pro is interesting...or?
You may have the board with 1451A "std" & CS8412.
There are also an extra IV board, can be set to different config, to suit 1543.
Boards are made of a forum-member far east.
All documentation (part-list & setup/test) is included.
Arne K
cobra2(at)online.no
ash_dac
Arne K
cobra2(at)online.no
Arne K,
Have you built one?
Is the documentation in English?
Note my cdpro mechanism is 2nd hand, and untested by me!
I cannot test the cdpro myself because I do not have a DSA protocol board, or the equipment at hand.
Kind regards,
Ashley.
Cobra2
They are buit & tested...
All info is in english.
The pcb's (1 dac + 2 analog) were ~ $ 100 empty.
Any reasonable offer gets them all. You will need trafo & chassi.
Arne K
matski
Hi all,
My first post and maybe it'll be of some use. I have a complete dac section from a cambridge audio cd2 spare. I built a good one from two dead units and have it available. It is complete,in good order and works as I have tested it. I didn't use this particular one as the other one had aluminium heat strips fitted to the tda1541 i.c's (x4) and seeing as the cd2 suffers a bit from cooking I used that one instead.
Mat
Page generated in 0.02786111831665 seconds with 17 queries,
spending 0.01128936 doing MySQL queries and 0.01657176 doing PHP things.
