I have read many posts but I don't understand the point of the NTC.
Can any tell me what's the point with the NTC-resistor?
Nelson Pass
The thermistor is used to connect the circuit signal ground to the
chassis and AC Earth. The thermistor provides some resistance
to avoid ground loops, but conducts well enough for safety,
and in the event of high current, it reduces its impedance as
it heats, so that the fuse will blow first.
roger-k
Ok. thank you very much for the answer Nelson Pass.
Page generated in 0.017354965209961 seconds with 17 queries, spending 0.00819659 doing MySQL queries and 0.00915837 doing PHP things.
