diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
parallel wiring 16 ohm 4 ohm - Click HERE for Original Thread
tobler
can i know if i can wiring two subwoofer one 16 ohm and the other 4 ohm
if i can what will be the total impedance that amplifier need to operate them
note : the amplifier is 2 ohm capable
ray_moth
You can but you won't hear much from the 16 ohm subwoofer because most of the current will go through the 4 ohm unit. Effective impedance will be (16 x 4) / (16 + 4) = 3.2 ohm.
tobler
is that mean that the 16 ohm subwoofer is useless?
my second subwoofer is (dvc) (4+4)ohm
what's is the best configuration for amplifier 4 channel (2,4,8)ohm capable
note: 2 channel is already occupied by 4 pioneer speaker
that is mean i wanna configuration for rest 2 channel
simon5
If your second subwoofer is DVC, then wire both coils in series, you'll get 8 ohms. Then ( 16 x 8 ) / ( 16 + 8 ) = 5.3 ohms
That way, your 16 ohms subwoofer will be more useful.
On the other hand, you'll be better to leave that 16 ohms subwoofer out of your system and wire your DVC subwoofer coils in parallel, so you'll get 2 ohms and get the most out of your amplifier.
What brand is the 16 ohms subwoofer? Subwoofers are mostly 8 ohms or less, unless it's a DVC 8+8 then you could wire it to get 4 ohms.
Page generated in 0.021404981613159 seconds with 16 queries,
spending 0.00960708 doing MySQL queries and 0.01179790 doing PHP things.
