diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Poinz 6AQ5 Linestage - Click HERE for Original Thread
dstockwell
OK you experts, can I substitue the 2.2uF 1200VDC Mundorf SS cap with either (2) 4.7uf 630VDC in series or will it hurt to drop down to 2.2uF 1000VDC. I just can bring myself to spend $43 a pop for the Mundorfs.
moamps
quote:
Originally posted by dstockwell
...can I substitue the 2.2uF 1200VDC Mundorf SS cap with either (2) 4.7uf 630VDC in series or will it hurt to drop down to 2.2uF 1000VDC..
One 4u7/630V will be just fine.
(I'm not an expert.)
Milan
dstockwell
Do you not need two 4u7 in series since the circuit calls for 2.2 :scratch:
Nigel Goodwin
It's only a coupling capacitor, so 4.7uF will be better than 2.2uF, giving better low frequency performance (although it's probably too low to make any difference).
kmtang
You only need 2.2uF 250V for this coupling circuit. 400V is more than sufficient.
I would get the Mundorf Silver in Oil cap for this which will give your detailed sound.
Johnny
dstockwell
Mundorf Supreme Silver oil, are the ones at $43 a pop, and the regular supremes are 1/2 that. $85 for two caps, I would rather go with the regular supremes at 1/2 that.
Page generated in 0.01970911026001 seconds with 17 queries,
spending 0.00635552 doing MySQL queries and 0.01335359 doing PHP things.
