diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Best Pass amp - Click HERE for Original Thread
MikeW
Out of all the Pass amps built from this forum, which is your favorite?
What are you building now?:smash:
SteveA
I've built an Aleph 5 (so it's my favorite for now). I have an Aleph 4 in process which means the main boards are stuffed and tested. I also have the chassis nearly finished. I have boards ready for the Aleph 2 as well. After that will come the Mini and the A30 and the Aleph X. Then I should be able to answer your question more fully.
SteveA
MikeW
Jam how do your DIY's compare to your X-600's? :D
mpmarino
Hi Mike,
I like my mini better than my 30 for a few reasons. Mainly I think it sounds better.
I'm currently building a BOSOZ, all home done.(long project)
Next is an Aleph X with~ 31-32v rails and an old ~3kva EI traffo. My heatsinks are all saved up and um, I'm gonna use a lot of output devices. Probably a number somewhere in the magnitude greater than that of a Pass commercial amp! My garage heater doesn't cut it as I get older:hot: (longer project)
Mike, you suggested I make something big. Will that suffice?
Why on the axe spreadsheet does it NOT reflect a power increase at rails above around 28v. The sheet seems to max out around 144w into 8R. Do I have an old sheet??
mpmarino
D'oh..me<=idiot. You've got bump up the bias.
moe29
The best amp is the amp that one finishes... and learns from : )
(i prefer my Aleph 2's)
((i learned the most from my Zen)
:devilr:
winslow
My favorite is my MiniAs...inspired by Pass.
They are my only Pass amps for now.
MikeW
:devilr:
I have built most of the Zens. Some of them sound pretty good. Most get taken apart for other projects. Good thing he goes step by step so he doesn't loose me. There is a lot to learn. Dual differential cascoded jfet bridged balanced single ended class A. Sounds like a new Aleph-X.
I still like the little Alephs (A3, Mini-A). I am sure there is something better on the way.:D
jh6you
Why don't you try F1?
With Aleph current source . . .
With a little bit feedback . . .
Hmmmmmmmm . . .
jH
MikeW
Has anyone done any boards for F1 yet?
steenoe
Acaudio and Raka has:) Take a look at this:
http://www.diyaudio.com/forums/show...8534#post758534
Steen:cool:
Tyimo
Hi!
I built the Zen, a Balanced 25W version of Zen, Aleph5 and the Zen Lite. Also the BOZ and BOSOZ preamps.
For me and for many of my friends and listeners the Zen Lite was absolutely the best!!!
I know this question is matter of taste, but so many peoples likes the Zen Lite? It is thought-provoking!! :-)
I would like to build the F2 yet. I think it will be even better......
Greets:
Tyimo
steenoe
quote:
I built the Zen,
Yeah, the Zen sounds great, whatever amp I have heard from NP, they all sounds great:D Right back to the first Threshold;) The ZenV4 has a great place with me though:) I dont think that man can make a bad sounding amp:D What the best is, I cant tell!
Steen:cool:
fcel
Don't we need to mention what speakers were used for this little discussion? Otherwise it won't make any sense. Example, Zen amp would certainly won't work with Apogee speakers.
steenoe
Fcel, you are right, ofcourse. Bringing up the Apogee's, they are too hungry for most amps;) They doesnt even sound as good as their reputation:) Big and hungry as they are, I dont kind of think they sound all that great. As NP stated a lot of times, you need the right speakers for a certain amp;) Most poweramps like easy driven speakers:) Take a look at these Apogee-clone roomdividers, a friend of mine made! Every poweramp connected to those, run hot like h#ll:D
Steen.
PS. I guess a monster Krell would be the thing for those:D
moe29
These are my speakers - They're Straight 8's from Bottlehead.
Around 97dB sensitivity.
mastertech
ZEN
Page generated in 0.041645050048828 seconds with 17 queries,
spending 0.00890350 doing MySQL queries and 0.03274155 doing PHP things.
