diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
LM3876 for guitar? - Click HERE for Original Thread
Wynand
Would I be able to use the LM3876 chip for a guitar amp?
If so would I be able to use the schematic in the datasheet, or would I need a buffer/preamp stage with or without gain.
I've tried to look around and couldn't find something to use.
If someone's got a relatively simple design I would love to see it.
matjans
hi,
i'd use an opamp in front of a standard lm3875 based amp (if that's what you're thinking of).
take any standard opamp, give it a high input impedance, say ~500kohm, and some gain. schematics are everywhere :)
Nordic
Hey Wynand, is lekker innie kaap vandag!!!!!!!!!
What speaker do you have?
I must say the basic inverted config is probably easier to put to together than the noninverted setup from the datasheet. Especialy with the mono 3875 version.
sagarverma
wynand
better use tda7294.they have better mid and up freq response.
lm series has good low freq response.it heavy on bass.
Tarzan
Marshall is using the TDA7293 as power stage in various combos.
They are ok. Use a decent heatsink!!!
Zilog
Page generated in 0.019931077957153 seconds with 16 queries,
spending 0.00802207 doing MySQL queries and 0.01190901 doing PHP things.
Please support our sponsor.
