diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
Is this transformer suitable for a sonic t amplifier ? - Click HERE for Original Thread
istari knight
hi, can you tell me if this will work well with the t-amp ?
http://cgi.ebay.co.uk/ws/eBayISAPI....AMEWA%3AIT&rd=1
if not , what would be better ?
thanks, james.
pcspinheiro
Well, you can get this one instead
http://cgi.ebay.co.uk/12V-DC-5A-DES...6QQcmdZViewItem
Its the same but 5A and you can probably get it cheaper as I got one from this seller for 1.04£ plus shipping! :D Unfortunatelly my 41 Hz Amp3 is still not fully assembled... :bawling:
Cheers!
istari knight
WoW !!!!!!!!!
thanks mate - have a drink :drink:
you've earned it !
istari knight
oh and nobody else bid on it , ITS MINE ! :D
panomaniac
Looks good James. Best of luck!
Just test to see that it doesn't send too much hash back into the mains - that could get into your other audio gear.
istari knight
Very true , michael mardis said the same:dodgy:
surely it cant be as bad as a standard wallwart ?
JaMeS
panomaniac
quote:
Originally posted by istari knight
Very true , michael mardis said the same.
Hey, that's me! ;)
Could be worse, at least as far as sending noise out into the mains. It is likely to be better than a standard wall wart for supplying the amp.
Let us know what you think when you get it.
istari knight
lol i should have known by your sig :clown:
i'll let you know how bad it is when i get it :cannotbe:
istari knight
hi again - just another question for you......
ive bought an alps pot so i need a seperate power switch.....
ive got one from my workshop but its rated at 2A-250v & 4A-125v
its one of those toggle switches , is it compatible ? or do i need something bigger ?
im in the uk btw so its only rated at 2A
thanks for the advice !!
Page generated in 0.035449981689453 seconds with 17 queries,
spending 0.00897384 doing MySQL queries and 0.02647614 doing PHP things.
