| valv pre?? - Click HERE for Original Thread |
| carlos671 |
will this pre amp be suitable for use with t amps? price is fairly comparible to the autosostruire pre i think. It is fairly expensive but i see the pre and phono stage as things i will stick with longer and experiment mainly with the t power amps. will probs start with a 41hz amp amp1b as stereo power then go mono. or should i jus get monoblocks straight away? as this is ultimately what i want.
http://www.worldaudiodesign.com/wad...s/series11.html |
