| young_pup |
Anyone know how to rewire the Power Humpty to run at 220-240V?
Frustrated!
Richard |
| sith |
| Umm, u have bigger problem, if u want it on Euro standard voltage, it is 220V@50Hz instead of 110V@60Hz. Humpty doesn't have a switch to change operating area?If not then u're stuck with changing power tranny, but why on earth u want to do it? There must be Humptys working on 220V ??! :confused: |
| Christer |
| Even if there is no switch for changing voltage, the transformer might be a dual primary one. Presumably it is cheaper to use one single type of transformer for all units, than to have different ones depending on market. But maybe that goes against their philosophy somehow? |
| Christer |
| Well, I assumed Richard had a unit he wanted to rewire, so he could just look inside and try to figure out it it has dual primaries. However, judging from the pictures in the link you provided Peter, I get a feeling the answer is no. On the close up of the transformer, we see the secondaries coming out on top, and at the botton there are two thick and two thin wires. If these had all been primaries, they would presumable have been the same width, so I guess one pair of wires is a third secondary for som purpose, and then the thin wires are probably the one and only primary. |
| Peter Daniel |
From what I see, there are actually 3 thin wires on primary side: one of them, grey in color, looks like connected to earth ground, but again, it's not very clear.
Point is, the supply probably cannot be converted to other voltage. |
| Christer |
| quote: | Originally posted by Peter Daniel
I can only see two, one blue and one grey, but if it is three, then presumably the transformer has a shield, which wouldn't be too much to ask considering what the thing costs. :)
| quote: |
I agree, but it still doesn't hurt too look inside the actual unit instead of just relying on pictures. There might differences between units. |
| young_pup |
Took the humpty apart...has 3 wires to the power socket.
Maybe i can photograph...but it is also marked on the transformer 120V!
| Christer |
| So, it is most likely not rewireable. Maybe the cheapest and easist solution is to buy a step-down transformer from 230 V to 110 V. |
| Peter Daniel |
So it means it cannot be rewired.
If you want, I can send you a toroid good for 230V and you'll send me the one from the Humpty. I was always curious how good they are ;) |
| young_pup |
Yeah...luckily i have one arriving soon. It is a pity though :) I would have liked to rewire it!
Thanks for all the responses!
Richard |
| young_pup |
haha...would be interesting to see! I'll be using mine with some nice Yamaha NS1000M speakers.
R |
| reMC |
| The blue and white wire in the PS are connected to the led ;) Furthermore, it has two wires coming from primary. |
