diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
SMPS Output filter inductor calculation. - Click HERE for Original Thread
corrieb
Hi All,
I am a brand new newbie when it comes to smps.
I am making a smps for a car audio amplifier , I have read a lot on smps design but can't find anything related to the designing of the output filter inductors. Can anyone perhaps help me with a formula/calculation?
Thank you,
corrieb
sagarverma
i have built a 300w smps.o/p inductors not used.i/p 12v passes thru 100uh inductors.hope this helps.
sss
i think bigger= better for those inductors (not too big )
u can take some iron powder cores with 10 turns of wire (thick), this works for me :)
corrieb
Thanks for the replies I will go and try tonight.
corrieb
buloi123
L=Ton*(Vin-Vout)/0.3Iout
The bigger the inductor, much better, for it can fixed more ripple current. But be careful w/ your inductor, as you increase your inductor value, the current capacity and saturation current of your inductor also decreases.
sss
if u are using output inductors where do u take the feedback signal? after or before the inductor?
corrieb
SSS,
I take the feedback after the inductor, other wise I am struggling to regulate the smps. why?
corrieb
sss
quote:
Originally posted by corrieb
SSS,
why?
because i'm also building one and dont know whats better :)
also , do u put the filter caps after or before the inductors?
Page generated in 0.021646976470947 seconds with 17 queries,
spending 0.00761461 doing MySQL queries and 0.01403236 doing PHP things.
