diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
A serious comparison between UcD180 and UcD400 - Click HERE for Original Thread
kephaudio
Hi to everyone,
I had the chance to listen to two different amplifiers with two friends who are audio-addicts like me.
Here the two configurations:
Amp 1:
two ucd 180 monoblocks, with audiograde R-core transformers each one with two secondaries, Siemens Sikorel Caps (10,000 uF on each monoblocks), silicon rectifiers (two on each amp)
Amp2:
two UcD 400 monoblocks, the same as the previous one with the difference that this one has toroids and BCH Aervox caps.
I think the first one was much over the second. I guess is due to the R-core transformer which makes a lot of difference on the extremes of the band (I mean 20-200 Hz and 16-20KHz).
The difference is more ROBUST sound, I would say in one word. For example take the Bach's fugues, with the 180 configuration I could reaaly feel the destroying power, the impetous of the sound. It was really like a tornado' 4mters form you. The space of the sound was wider, more present, the immage perfect.
In a word I would say that both of them were correct, low distortion I mean. But in terms of MUSICALITY the 180 configuration was much better.
I also suspect that the difference of Caps is central. Sikorel are somenthing really over the top.
Yes, with ucd 180 you have less power, but you have the chance to buid a really good power supplay. As the experience with Naim preamp power supply tought me, I now understand that what really makes difference with amplification is the transformers. Toroids are not that great, they sound flat, the sounds they produce is like a beautiful well educated women, say a queen, but without sex attitudes.
The power is not a problem in a two-channel hifi system. 20 excellent Watts are enough for a 90db speakers in a 6x6 meters room.
The problem with the 400 is that for instance you cannot find good R-core. Even better than R-core we have C-core, but they cost a lot and VA rating could be a problem.
Let me know if you have other experiences, I would really like to hear from you about comparison between 180 and 400. But I am talking about audiophile applications where sound QUALITY is the only thing that really matters.
By I hope to hear form you soon,
KEPha
classd4sure
Hmmmm
Plug the 400's into the 180's chassis and get back to us. I feel your comparison falls apart at the different caps, like you said.
What don't you like about foil coils?
Toroids no good?? hmmmmmmmmmmmmm
Well, you're not afraid to go against the grain, I admire that :)
Chris
stef1777
A "serious" comparison will be to compare the same UcD module with two different PSU, nor to compare UcD180/UcD400 each one with two different power supply.
kephaudio
quote:
Originally posted by classd4sure
Hmmmm
we have already done that. The 180 is still better, I guess this would not be corect anyway since the 180 Psu has no enough VA for the 400.
quote:
[i]
Chris [/B]
Mmmh! I am not the only one! Look at a well known webpage
http://www.acoustica.org.uk/t/naim/powersupplies.html]
Anyway, what I don't like is the artificial satin that they give to sound. Maybe I am not able to express what I mean in English but look at the link above, it is clearer there, I fell the same as they explain.
Are you sure that toroids are better? Maybe these believes is only because to produce high VA rated transformers they are the only kind of wound which are affordable.
With my circle of friend we have tried to compare different audiograde transoformers on commercial amps (20-50Watt on 8Ohm) R-core and C-core always beat the 'famous' toroids.
ciao
Kepha
classd4sure
ciao
Kepha
I'm sure toroids are better for EMI purposes anyway. That has to relate to better sound too.
People always worry about their english :) You're expressing yourself perfectly!
I'll read that link after I have a little rest and watch a movie, but I accept your opinion/observations. I haven't heard both amps so I can't give you mine, just thought this is very interesting.
Are those stock modules? What versions, what revisions?
Thank you and thanks for posting what no will no doubt turn out to be a very interesting thread.
Chris
kephaudio
Hi dear,
quote:
Yes, you are right, the problem is that it is very hard to me to find a good audio-grade R-core transformer for the UCD400. If you know a good europen seller please let me know.
We used the
http://www.hifituning.de/html/r-core_trafos.html
which are very well known to be over the top for audio applications. As you see form the link they do not produce a good one for the Ucd 400.
I think the ocmparison is 'serious' anyway, **except the power** the 180 and 400 where playing very similar both with toroids and BCH aervox...played in the same system of course (I forgot to mention this). They had the same sound, the only difference was the maximum power, which didn't make so much difference with 90dB speakers in a 6X6mt room.
So changing the transformer and caps in the 180 the quality of sound changed a lot, I guess my conlcusion is therefore correct.
Please put attention on this: I am not talking about distortion, dynamics and so on. I am talking about MUSICALITY which is the true difference (in my poor view) between excellent amplifications and over the top amplifications.
Sorry to have not specified some important detail of the test.
Bye for now,
KEPha
classd4sure
OK I was confused earlier, thought you were comparing modules and it seems you're more comparing power supplies.
Ignore me I'm going to sleep :)
PS: How is the mechanical hum?
kephaudio
Chris
You are right, but we built a cabinet with a separate box for the transformers with an extreme shilld grounded properly, under working condition we measured the EMF around the separate bow of the transformer...perfect shileding!
We bought the modules at the beginning of September, they are the improved version (more expensive)
Ciao,
Kepha
kephaudio
Anyway this is interesting too! My point is that it could be that the difference between them, except the power is not that great. but I think the psu can make a huge difference.
I have the impression that, whenever is possible, we should explore the use of different transforomers..I think -- and I am not the only one -- that toroids sound their way, maybe ones like that sound, but it is still possible to get better more PRESENT sound with other wounds.
Also the point is that less power means that with same money you can buy better component, i.e. possibly better sound. Do you really need 200Watts on 8Ohm in a small room? Ok if you have Infinity RS Sigma you need even more, but that kind of speaker are only exceptions. We now have more efficient speakers and we don't need so powerful equipment. What we need is quality. That is my philosophy, but I respect other point of view.
Ciao
KEPha
maxlorenz
Thanks Kepha for your interesting observations :)
I think you are wright on the path: better PS.
I remember even Bruno complained about PS caps being so influential on final sound from the amps. And later, independent PS to input opamp.
I manage to find suitable Sikorel's (thanks ACD) and unfortunatelly I had to buy Plitron's 500VA toroids because I didn't knew about R-cores. I'm plannig to use small R-cores for low voltage projects like CDP and DAC's (and possibly UCD's input PS) .
Could a big EI 1:1 isolation transformer paced previous to the amps imitate the R-core effect?
Mauricio
cowanrg
from a scientific stand point, it sounds like you were ONLY testing transformers, not the actual modules. that is fine, but you cant say that you were testing the 180 vs the 400. thats not what was happening.
BOB LEWIS
RE. C-core versus toroid transformers:
The following are the advantages,disadvantages which I`ve gleaned from reading various transformer websites;
C-core has typically 30db better EMI suppression,the core saturates far less and has less mechanical hum when DC is present on the mains supply,greater energy storage and lower harmonic distortion.
Drawbacks include greater cost , bulk and radiated magnetic field,the latter requires some sort of shielding to cure problem.
Hope this is useful.
Bob Lewis
kephaudio
quote:
Well, yes agree that the title of the post is not very accurate. But I wanted to tell our experience with the two modules with different power supplies. I think in my first post I didn't -- at least I didn't want to -- put 180 vs 400, indeed I was talking about the two "configurations" (amp 1 and amp 2).
Anyway in one of the replay I also explained that we tested the 180 vs 400 both with the same psu (same topology, both with toroids and same caps) and as I said we didn't find any relevant difference in the SOUND quality, they both had the same flavor.
Of course I immagine that turning the volume at the very right we should have seen the difference in terms of power...but we didn't! With 90db speakers in a 6x6 room we couldn't! These babies cry so much!!
Maybe friends from Hypex can tell us more, they tested their amps I guess in many conditions. But I am almost 99% sure that with the similar psu the only difference is power while SOUND, ceteris paribus, would be strongly dependent on PSU component and topology.
At the end this is not new at all. We know that psu is the relevant bit which makes huge difference on the CHARCTARER of the sound. Sound is body and soul, I see the amp as the soul the power supply as the body.
Two years ago my brother was complaining that his NAD amp (2x50W) was lacking of basses, we rebuilt the psu with good components and the sound cheanged as night and day.
Ciao,
KEPha
kephaudio
Bob Lewis
HI,
I am not an engineer, but I think I have experience with different transformers because I am into an audio-addict comunity where a lot of friends like to make crazy experiments with different transformers and psu topology. I have been listening to amps with different psu from a long time.
I don't know the scientific reason, the only think I know is that C-CORE are the best. If you care about money then toroids are the best think you can have, but no good toroids can beat a good C-CORE or a R-CORE for what concearns the sound.
BUT again I am only talking about SOUND. With toroids usually I experienced that you loose the sound stage, the PHISICITY of sound, as I said it's like the sound has a VELVET on it which is not natuaral, maybe people like that but personally I find it artificial.
Bye,
KEPha
BOB LEWIS
KEPha,
I agree with you about the sound of C-cores,they appear to give a feeling of unrestrained dynamics and presence. I`ve been using C-cores on my amps for the past six years and wouldn`t go back to toroids.
Bob Lewis
kephaudio
KEPha,
Bob Lewis
Hi
have you ever tried R-core, in my experience C-core are better than R-cores but R-core are still better than toroids.
I see that you are from Great Britain, where do you usually get C-cores, now I am working in London. I know that the best c-cores are those by Lundhal...but they cost money not nuts!!!!
let me know,
KEPha
BOB LEWIS
KEPha,
My C-cores are from Avondale Audio UK,750va with double mono secondaries. Never tried R-core although my SONY SACD player has a pair of them.
As for the best C-cores,have you seen the AUDIONOTE ones?
Their top versions feature nickel cores and silver wire,some costing nearly £3000!!!!!
Bob Lewis
classd4sure
KEPha,
Bob Lewis
Wow, how about the worst/cheapest?? I paid over 300 for a 500VA with static screening and magnetic shielding... yeah I feel ripped off, thanks Plitron @%@#$%,just like at Macdonalds, no special orders!!! The magnetic shielding seems worth it though.
BOB LEWIS
Classd4sure,
If you want to read an in depth technical article why C-cores are the best go to the AUDIONOTE website ,click on KITS and COMPONENTS,then TRANSFORMERS.
First scroll down the page to see the mind boggling prices of these things!
Bob Lewis
cowanrg
i just think its silly to even test the two amps (ucd400 vs ucd180) with that test system. a 90dB speaker in a 6 x 6 room wont even need anywhere NEAR 180 watts, let alone 400. so, there is no point to even throw the ucd400 into the mix. you could/should have just stuck with testing two 180's with various power supply options.
valvaholic
kephaudio (or anyone else, really):
How do you feel about valves?? Have you or any of your audio buddies compared the UCD offerings to a good tube amp?
I'm quite interested in how they'd compare in terms of tone, timbre, and dynamics. TIA
cowanrg
there have been some threads regarding that in here. i think in the ucd180 thread there are a few people that have compared. do a search for tubes in the class D forum and see what you come up with. i remember several people comparing the two, one guy had pathos, maybe that will come up in a search.
kephaudio
mmh! If you think this is silly...I suggest to you to not read this post. Simlpe, isn't it?
If you are so smart for this post, thank you very much indeed for your illuminating contributions an bye.
I am an audiphile I have never seen people listening to music in rooms greater than 8x8mts, say. So it is certainly silly to test an audio equipment in a stadium.
Many watts in audio are not supposed to play in stadiums; they are supposed to exist to drive extremely heavy loads. I know people that get crazy to drive Infinity RS Sigma, of course if you have 350 good WATTS they are the best think I have ever heard...but 350 good WATTS are not nuts.
For me 50 good watts are just enough for a regular system unless you have inefficient speakers less than 82db, that is another story.
Why we did that? Because, there are people that were suspecting that 180 and 400 sound different. We don't think so.
And now for the last time I will summarize the test (and if you don't like it, that's fine for me):
1. with the same psu topology and components they sounded equal unless for the maximum power which we didn't care about.
2. We couldn't build an R-Core based psu for the UcD400 (simply beacuse we didn't found a good rating).
3. we did the R-core based for the 180 which was estremely better than those based on toroids.
I liked the test, this shows to me (maybe not to you, but that is ok) that at least the 180 is not worse than 400 in terms of SOUND QUALITY.
So I will personally go for 180s and I will put the extra saved money on components. Less VA for a trsnformers means less money, less mF for caps means less money. Conlcusion with the same amount of money I can buy much better component that at the end I know will affect the SOUND.
I hope this helps to solve your puzzle about the stupidity of this post, I also hope that now you want to propose some serious argument.
Bye
KEPha
cowanrg
no need to get hostile.
first off, i apologize, i didnt realize you were talking meters. me being a stupid american, i forgot 6 meters is much different than 6 feet. i half-assumed it was meters, becuase a 6 foot room would be TINY, but still. i didnt realize what size exactly 6 meters was.
my major problem with the whole test was that you didnt care about maximum quality. so, why even introduce the 400? if your goal was to test a ucd180 vs. a ucd400, which you claimed, then use identical power supplies (the same ones for each, regardless of quality, you are testing the modules, NOT the supply).
BUT, if you want to test power supplies, use two ucd180's. there are just too many variables otherwise. that is all im saying. i understand now that you did test the 180 with and without the nicer transformers, caps, etc. but it would have been nice to have two sets built and do an A/B comparison, because rebuilding them takes awhile and will be hard to judge.
plus, the title was a bit misleading. it was really less about the two, and more about the power supplies. and earlier in the post you had a different idea about the two. you stated the 180 sounded better than the ucd400, and you didnt really say it was attributed to the power supply. now you are saying they sound the same. its just a bit inconsistant.
i understant completely what you are saying now, and its fine. there was just confusion, and im just telling you what it was for me. thats all. its not personal, its not an attack.
kephaudio
I am not a tube guy. I like tubes forom 200Hz to 20KHz, but in the intervall 20Hz-200Hz they just fall down. There good tube based amps that behaves very good at low frequencies...but with huge complication for speakers and money!!
I have also listen to a system based on hybrid amplification, it was too artifical for my tastes.
But I think that class D amps have the advantage that they are the best compromise between tube and transistors. I mean the UCDs have some features of tube amps, just listen to the high spectrum (above 10000) they are as smooth as tubes. But they have the advantges that at low frequency thay sound better than tube at a fraction of the cost.
But I think that experiments with different PSU are of extreme importance. PSU, and in particular the transformers, affect sound consistency in a drammatic way. I had many experience with that.
I would be very interested to listen to an UCD with C-cores form Lundhal
http://www.lundahl.se/
the best that I am aware of. Now I cannot spend more money otherwise my wife ask for divorce :-), but as soon as I can I want to try!
KEPha
indoubt
How about "O" Core transformers?
I've never had a change to listen but they are assumably even better than R-core.
I've a link to a supplier (pretty close to italy)
If you have sufficient power for your UCD400 with 37Volts of your tranny they have also 650VA R-cores but I guess they will make whatever you require
http://www.hifituning.ch/transfor.htm
kephaudio
That's ok, but please read carefully. I am not an English speaker but I think was not so unclear, again you missed somenthing. Le us see:
because as I said before there are people that belives that with the volume's knob in the very first 20 degrees of its rotation, the 400 sounded better. We didn't belive that and we try to find out.
again: if you are aware of a good R-Core with 42/45 V secondaries and at least 500Va, please let us now.
as soon as we have good trafos for the 400 wi will let you know.
I already admitted that I made a mistake.
where?
read the original post: I was talking about the two configurations, I have never said that the MODULE sound different. I think they sound equal with equal PSU topology.
quote:
[i]
very with that. I suggest to everyone to make experiments with different trafos. It will be surprising if you have thoght that toroids are the best think you can get. That is false. And it also false that Caps play a big role, at least they do not has impact greater then tranforrmes. I have being doing these comparisons from months. I started to do it when I had the problem to supply a NAIM 42.5 (great stuffs).
I hope to hear from you gain,
KEPha
kephaudio
quote:
No experience with that.
I would personally go for C-cores. I know them...great stuffs.
this is my supplier, serious and perfect! It's R-core are over the top. It doesn't wound on order unless you require something more than 5 pieces. The 37Volts you mentionare not realistic for the 400. You need more.
Bye
KEPha
indoubt
Well, you should of course never directly believe what they write on a website but this is what they say:
"O-Core Trafos":
Absolutes High-End-Material! Für Endstufen kennen wir keine besseren Transformatoren...!
(in English: for power amplifiers we do not know any better)
That is why I was "refferring to it as: assumably even better
I do not have experience (yet) with both C, O and R cores.
cowanrg
could you run two 400-500va R-cores in parellel for use with a ucd400?
t.
Good Post KEPha
Have you listened to the Naim amps?
I currently have an AvondaleNCC200 amp, I'm ordering a pair of UCD modules soon and wondered how the UCD180 compare against something like the NCC200 which is based on the Nap series amps
kephaudio
I don't know. Usually I don't do experiments like that if I don't have direct experience...it costs money not nuts!
Anyway, I will be away form my desk for a couple of weeks I don't know wether I will be able to reply to posts.
I told you my experience, I hope this encourage experiments with different power supplies, mainly with different transformers. I don't belive what Nypex guys said about the importance of Caps. I strongly believe that sound is much affected buy the topology of the transformers (i.e. the geometry of the core, wound etc.). I think this makes a real difference in sound.
Since I don't think I explained very well the difference between Toroids and R-cores (even better C-core) due to my bed use of I now have a 'chic' metaforae:
Toroids sound = female, Concorde
C-cores/R-cores sound = male, F16
I think this makes a better idea of the word I used erlier (robust sound)
Bye and I wll reed your posts on the topics later,
KEPha
matjans
0-core? looks like a toroid to me ;)
kephaudio
quote:
Originally posted by t.
Good Post KEPha
Yes I have 42.5/140 and I started to play with psu when I started to build the psu for the 42.5. Follow the www.acoustica.org.co.uk and look for psu, over there you will find good comparisons with R-core, C-core Toroids and different caps.
I played the 180 with the 42.5 (I had big trouble with the DIN connectors, very hard to do good cable due to soldering in extremely small spaces). Excellent stuffs I think. But this is not surprising I think the Naim's Preamp can drive everything and the UCD can be driven by everything...so nice! Naim's guy are very smart becauswe they give impresion that you can play a system only if it is all-naim based. I think this is fals.
I hopo you will do experiment on that. If you do it, please let me know on kephaudio@yahoo.it
Bye for now,
KEPha
ninjanki
Kepha,
I think that the importante of the transformer on sound quality is, sometimes, understated. But it is probably not more important than the capacitor quality, as you said.
Thinking about it, I considered that, for some period of the cycle, the amplifier is draining power directly from the transformer, and the Caps are there just for the ride, and to make the transformer life a little harder(during this period, the transformer is also recharging the cap). On the rest of the cycle, the rectifiers block the transformer communication with the circuit, and the amplifier has to drain all its power from the caps. So, it is quite reasonable to consider that the transformer might be as important as the cap. Actually, it might also require the consideration of the usual power draining levels of the amplifier. the more power is drained in average, the more important is the transformer, cause the charging period get bigger and bigger.
Allan
indoubt
quote:
Matjans,
The difference is not that big except that the cross secton is circular, there seem to be certain advantages but I do not know the impact on sonic performance other as what is mentioned on the website. Core saturation seems to be less.
Kepha, do you know where to find C-cores? most of the suppliers do not have them.
general:
Would it make a difference if a torroid has additional screening between primary and secundary and is encapsulated? Would it come closer to R-core?
kephaudio
Matjans,
general:
HI,
for many years the best was considered
But I am aware of better think produced in Italy for example the now famous Bartolini distributed by
http://www.audiokit.it/ENG/Frames/Introduction1.htm
who also sells Kendeill Caps (very good). The problem is that I find Audiokit a bit expensive, but from what I know is the only one who sells Bartolini's C-core. Notice that Bartolini is a kind of artingianal family company they do not have a web for example. But very well done stuffs. In Englnd I know tha Audionote has good stuffs
http://www.audionote.co.uk/index_comp.htm
but very very expensive. C-core are used in many project with 300B tubes.
I don't know about the other question, sorry. As I said I am not an engineer, I am just audio-addict and experimenter and I am looking for good consistent sound.
Dude,
KEPha
kephaudio
sorry the name is Bartolucci instead of Bartolini, they two popular italian surnames which I always confuse...sorry
ciao
K
Robert F
This is an interesting thread. I do think we need to be careful here in attributing characteristics to a certain technology when
there will be variations in quality within one type. For example, Mike Elliot formerly of Counterpoint published an article critical of toroidal transformers but changed his mind when he heard a Plitron. Steve McCormack was the same but now likes Plitron transformers so much he offers them as upgrades to his amplifier designs.
A major factor affecting performance will be whether an electrostatic screen is specified with the Toroid or not. Without one there is very little isolation from mains noise, whereas an R- core will have isolation as a result of the spacing between primary and secondary windings.
I suspect different toroidal manufacturers may tolerate higher flux densities for a given va rating than others which may well contribute to inferior results.
Just a few thoughts.
Rob.
hpsxr
My two cents.
Toroidal transformers tightly couple the AC line to the secondary in wideband manner (MORE NOISE) but is possible have an electrostatic shield in toroidal transformers.
Toroidal transformers tend to saturate much more abruptly and need to be over rated by a much larger factor.
The quality of the caps is important.
Hugo
maxlorenz
I will ask again because noone seemed to notice my first question :angel:
Probably I will never get my hands on BIG R-core Tx. :bawling:
Could a BIG (+/-2KVA) EI, 1:1 isolation transformer imitate the benefits expected with C-core or R-core Tx?
Thanks in advance.
Mauricio
Coolin
Yes.
Low frequency noise will be filtered very well and depending on winding method high frequency noise will be less as well but not to the same extent as an R-core.
Another way this can be acomplished for some part is by using two transformers in series (primaries)
maxlorenz
Dear coolin:
Thanks! :D
Very kind of you.
Best wishes.
Mauricio
PS: and will block DC :cool:
pirinyo
I played the 180 with the 42.5 (I had big trouble with the DIN connectors, very hard to do good cable due to soldering in extremely small spaces). Excellent stuffs I think. But this is not surprising I think the Naim's Preamp can drive everything and the UCD can be driven by everything...so nice! Naim's guy are very smart becauswe they give impresion that you can play a system only if it is all-naim based. I think this is false.
Bye for now,
KEPha
Hi!
Can you compared the NAIM NAP 140 and the Hypex 180 directly?
Please inform us about the difference in sound !
I am to order two hypex modules I am also have NCC200 Avondale amp with EAR tube preamp
t.
quote:
Originally posted by pirinyo
Hi!
Sorry I can't help but I'm in the same position as you:) I already have NCC200 with a pair of cap-6 supply and a pair of Holden and fisher toroidals.
I also would like to know how the UCD's compare and if they would be a worthy upgrade
lucpes
My standard practice is to 'treat' every AC input (trafo input) with two ferrite chokes, one on hot and the other on neutral (like the ones you get from PC power supplies) and an 0.047uf capacitor - quality (polypropylene 400V or so) placed between hot and neutral after the chokes (across the trafo primary). Really makes things sound better at least in my case.
Page generated in 0.14977407455444 seconds with 17 queries,
spending 0.00891328 doing MySQL queries and 0.14086080 doing PHP things.
