diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
Car audio Amplifier - Click HERE for Original Thread
willo
Hi, I need an help for my car amplifier.
I don't know if you can help me but I try!
I have an audiophile system, 2 way Dynaudio MD100 + MW160 LQ with a cd-player Nakamichi CD45z (20bit) and my amplifier is a Nakamichi PA1004 (50Watts/ch, 200W).
Before I had a Rockford fosgate POWER 500a2 but the MID and TW are not so good and hi quality as Naka also if the soud now is more soft and smooth (NEAR TO MY HOME TUBE AMPLIFIER Primaluna two 45W/ch).
Now some people suggest me buy a Phoenix gold (which kind of model?), Zapco or old Soundstream but I don't have a good idea what's the best audiophile amplifier of all.
For me is important to have a good power 'clean' and natural sound.
Any answer will be apreciated.
William.
anatech
Hi William,
If you're happy, why change the amp? Just wait until you hear something you like better.
I have a pair of older Nak. car amps that I like. And some older ones. I see no need to change for the sake of change.
-Chris
willo
Thanks Cris, We need to discover a better amp but sometime we find a bad surprise.
I need only more power and in Italy we have the only source of Nakamichi and not amplifiers.
Do you know some reseller in Canada or Usa that can sell these products in Italy.
I found out Onlinecarstereo but they work only with USA.
Bye
William.
anatech
Hi William,
I think it's safer for you to buy from within the EU. I am not sure what the lineup is for Nakamichi, but high power was not their market. McIntosh makes really good amps as well, again more high end.
I guess you need to ask the "pounder people". Their definition of "sounds good" is different from mine.
-Chris
Cal Weldon
I have moved this to Car Audio
sdoom
hi willo ,
as you are from Italy, why not go with a 100% Italian product ? You should really try the big Audison amplifiers.
Those are one of the last real European made - products. Most of those I heard are "warm and strong" sounding and the bigger models deliver plenty of power. You should be able to find a dealer that sells Audison amplifiers where you can test the amplifier in your car.
www.audison.it
mr.lex
Hi Willo,
You should test audison:) The character of this amp is soft and smooth. In Sweden we always like amps of Italy. Becuse this amp have a realy Hi end character. I's a few manufactures in Italy made realy hi end amps. This car amps have the real hi end home hifi amp!
trusound
Sinfoni is also made in your backyard.....incredible amplifiers
sagarverma
use sony xplode series.i dunno bout any of the amps mentioned here but i really appreciate sony222 for speakers and sony444 for woofers.
2 each for speakers and woofer (bridge)and u have a great distortion free and blasting o/p.these are class d amps and surprisingly ,no detail is lost even at max volume.
but the woofers and speakers of xplode are not 'heavy'..pioneer has great woofers and speakers.
i have heard it in many a cars and completely flattered by quality and power.
sdoom
Well, sorry for beeing honest. Sony stuff is junk
They have a couple of good head units but the amplifiers are mid range class products. They may be a lot better than the standard korean stuff, but they will never show the quality of an audison amplifier . Why I know ? Because I have fixed probably 20 Sony amps , the older models (XM5540.....etc) are ok as they are very cheap now, but the newer models really canīt compete if you wanna have a high end system.
@willo: If you want to save money, look for an old Generation X Zeus (Hifonics) , this is the last series developed by Stephen Mantz . I used the Zeus for two 15" modified woofers as shown in the pic.
At first I used an AudioArt 400.2 amplifier, a very good and warm sounding amp. It had plenty of power to drive those modified woofers, problem was that I couldīt get rid of the heat at that time so the AudioArt squit working after 30min. because of overheating. The AudioArt would also be a good amp for your needs.
Then I replaced the AudioArt with the Zeus, even more pressure and clean bass, and no problems anymore with overheating. The older hifonics (series 7 , series8) and SoundStream models are also ok, but they have more noise compared to modern amplifiers, that would still be ok to drive a sub, but I wouldnīt use them for normal door-speakers.
But try to find a dealer that will let you test the Audison amplifiers in your car. Independent of what we say, Iīd suggest that you let your ears decide what amp to use for your speakers.
Steph
sagarverma
well , i like sony amps very much.they r distortion free and great.i dunno bout amps u talkin bout,sony is sufficient for me.;)
willo
Thanks so much for your preciuose information.
I'll take in consideration your suggestion to test a AUDISON amp but recently I tested a new Steg MASTER-STROKE amp in CLASS A (calss A upto 25W then AB up to 100W) but the sound was a desaster! I connected a simply Rockford Fosgate punch 40ė (20W/ch) and it was a little bit superior like power!!! ( I mean 20W match 50W!)
The USA amp are better for the power, dynamic, clean and S/N ratio.
The Steg amp are better for musicality on MId and High frequency but the bass is a desaster.
Really bad, in any case I'll test the audison amp also if I'm not very curiose.
Thanks a lot
Bye
William
sdoom
Hi again,
Have you tried a Signat RAM 3 MKII for the woofer? Those amps are also high quality (gold curcuit lines and stuff) and they are also rated as class a......not sure about that :clown: (considering the power it would have to waste) but it is also a very good amplifier . I use the Ram 3MKII for my subwoofer in my winter-car (as I get oldr I donīt need the high pressure levels anymore :clown: ) the Ram is a good buy amplifier, used to be very expensive but now they are around 50€ on ebay, delivers 2x150W RMS and bridged ~ 400W into a 4 Ohm load, also 1Ohm stable in stereo.
Page generated in 0.03551197052002 seconds with 17 queries,
spending 0.00804305 doing MySQL queries and 0.02746892 doing PHP things.
Copyright Đ1999-2008 diyAudio.com
