diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
Rockford Fosgate 2000 Watts Max - Click HERE for Original Thread
datboip
My speaker has a dent in the center...
How do i fix the dent?
(I posted this in the wrong are on the forums...lol)
TO-3
Easiest way is to stick a pin in the center and carefully pull the dome out.
ghudnub
quote:
Bend the tip of the pin 90 degrees. It will work pretty good. I did it to a pair of Cerwin Vegas a long time ago. Some of the wrinkles may not totally disappear, but it will look better than what you have now.
boxcustom
turn the speaker around. stick the eraser end of a pencil thru the vent hole in the magnet. push the dent out with the pencil. u can also use duct tape on the front of the dust cap. take a piece of tape , it has to have good adhesion. push the tape hard to the dust cape. pull. dent should come out without making a nasty hole from a pen, yuck.
sound_prodigy
You could also use a vaccuum to suck out the dust cap but turn the vaccuum on after u place it on the cap so u dont screw it up. Then turn the vaccuum off once the cap is up. Tried it several times... always works.
Page generated in 0.022520065307617 seconds with 17 queries,
spending 0.00879002 doing MySQL queries and 0.01373005 doing PHP things.
