diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Speaker dent - Click HERE for Original Thread
datboip
A buddy of mine just sold me a speakr...
and the inside dome thing is bend in...
its an wesome 2000wat speaker...
how could i fix the dent? :bawling: :confused:
I searched tha fourms and only saw somthing of a dust cap dent...
This is diffrent.
motherone
I'm assuming that the dust cap is plastic. Use some tape and try carefully to lift it back up. I know planet10 and a few others have some techniques they use for fixing this stuff.
Bob2
If you have a good shop vac, just stick it on fire it up, should pop right out if the vac is strong enough.
Vikash
quote:
This is diffrent.
The dust cap is dented. How's it different.? Tape or a vaccum will work fine. I prefer Tape.
BassAwdyO
Method 3
Take a dowel of wood and some hot glue. Hot glue the dowel to the middle of the dustcap dent and let it dry. Then pull the dowel out and pop the dent out. When you're done simply peel off the hot glue and dowel. This should work rather well as the dustcap is probably some type of plastic and hot glue will not penetrate it and peel off after a bit of prying. If the dust cap is some sort of cardboard or paper... It will rip some material off.
I'd say this method is probably the easiest and most effective. Tape will work only if the dent wants to pop back out or the material is flimsy(I'd guess its not judging by the type of sub) or you have some REALLY strong tape. The shop vac probably wont work too well because in my recollection RF makes their dustcaps with a 3-d logo and the shop vac will likely not provide adequate suction even with a very high power vaccum.
P.S. that is the dustcap of the speaker....
Volenti
Another, more direct, option is to remove the metal mesh from the pole vent and use a peice of dowel or similar to push the dust cap into shape from behind.
datboip
i kinda forgot about this, because i havent bought an amp for the speaker. but now i got one, and i will deffinately try tha hot glue.
and wood thing.
i aint kno it was a "dust cap"
looks more... dome-ish... not cap-ish.
datboip
oh and check it out, go to google.com and search my name.
DATBOIP
this thread will be near the top. lol
BassAwdyO
yeah.... or you could search for "speaker dent" and this thread would be #1
chops
I had the 15" version of this sub, and from looking at that pic, the surround looks as though the cone is pushed all the way down towards the backplate of the magnet.
Does the cone move back and forth freely? My friend had a JL Audio 10W6 that froze in place in the down position. I'm guessing the VC welded itself to the pole piece. You better check and see if that Rockford isn't the same way or your "friend" just sold you a dead woofer. :eek:
dfdye
quote:
Originally posted by chops
. . . from looking at that pic, the surround looks as though the cone is pushed all the way down towards the backplate of the magnet. . .
I'm guessing the VC welded itself to the pole piece. . .
I was just thinking the same thing! My bet is that even if you do get the dent out, it will take a little "convincing" to get the cone to move again. Has anyone successfully gotten a cone like that unstuck? If so, was the damage to the VC severe enough to knock out the whole driver or was there some way to make it work again?
amp-guy
here is my tried and proven method.
using a hair dryer warm the dome till it is soft and pliable.
take a 6inch or so long piece of duct tape and place the center on the dome.
burnish the tape down over as large of an area as possible.
pull on the tape (holding both ends) slowly till the dome returns back to shape.
you may need to heat the dome further to remove all the creases.
Caution if the dome is poly be carefull with heat -you may melt it!
:bawling:
of course you can allways remove it and buy a new one from
WWW.partsexpress.com
I have used this method sucessfully on thousands of drivers
over the years.
Good Luck Dave
chops
:bawling:
over the years.
Good Luck Dave
That's all fine and dandy, however it's also a moot point if the driver itself is hosed.
Volenti
Also it may be something as simple as the sub being stored for a period of time with something heavy sitting on the dustcap (probably another sub :rolleyes: ), The result is a (more or less) permenently collapsed spider, unfortunatly I've seen far too many drivers rended useless like this from incorrect storage/ignorance.
dfdye
quote:
Originally posted by Volenti
Also it may be something as simple as the sub being stored for a period of time with something heavy sitting on the dustcap (probably another sub :rolleyes: ). . .
LOL! I think you have it!!!
That possibility didn't even cross my mind, but that would account for the SEVERE dent in the dust cap. That is far beyond what I would suspect would happen from everyday negligence.
Destroyer OS.
Who does that? I bet some one that does not refrigerate milk and can not figure out why it is never fresh does that.
Relax
Hehe
I can see some of my friends wondering why their non-refrigerated milk isn't good anymore...
If the dent is very severe I have done the dowel through pole piece vent. 2 people helps cause one can hold the cone and the other push the dowel.
Page generated in 0.046686887741089 seconds with 17 queries,
spending 0.00800061 doing MySQL queries and 0.03868628 doing PHP things.
