diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Driver electrical model - Click HERE for Original Thread
sovadk
Hi
I want to simulate a woofer in a closed loop by use og an accelerometer, and need a driver model for this.
I've found one (attached) buth the frequency responce seams very limited (breaks at 30Hz+), so I assume it isn't correct.
Do you have a better model?
Regards Kaspar
f4ier
Leach's Computer-Aided Electroacoustic Design with SPICE should give you an idea. Have a look at his site for other material as well; particularly the article regarding lossy voice-coils.
Remember that these models are only valid up to frequencies just before cone breakup. Moreover, these are small-signal models.
Enjoy :)
Svante
...and no baffle step.
sovadk
Thanks I'll have a look at it
Page generated in 0.017559051513672 seconds with 17 queries,
spending 0.00757504 doing MySQL queries and 0.00998402 doing PHP things.
