diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
Nuuk's active pre for Si T-amp... - Click HERE for Original Thread
ThomasS
Can the active pre run on +/- 13v? (SLA power my SI T-amp and it would be nice to do the same on the pre)
Can the gain be increased to ~6dB? (PLLXO causes some insertion loss in my bi-amp system....)
Thanks,
Thomas
ThomasS
The pre amp is described here:
http://myweb.tiscali.co.uk/nuukspot...inclonepre.html
The voltage is specified to 15+ v - but what about 13v....
Thomas
ThomasS
What's the output impedance of this pre amp?
There is a 100k resistor between output and ground :confused:
is this correct?
Thomas
ThomasS
I could just build it and see...... BUT I would prefere some gain....
Thomas
janneman
The 100k doesn't harm but would do anything either i think.
13V supply should be OK with possible a little less output level - but still enough to wildly overdrive your GC!
This is a buffer (if I got the right diagram on the site) so no gain, I'm afraid. You really need 6dB gain? How about just turning up the vol control a bit further, or rather turning it less far down?
Jan Didden
janneman
Correction: The 100k ensures the output floats to gnd if connected to a capacitor-coupled power amp input.
Nuuk
Beat me to it! ;)
ThomasS, you may find that with the buffer in between the volume control and class-T amp that you don't actually need the extra gain! :att'n:
janneman
quote:
Originally posted by Nuuk
Beat me to it! ;)
[snip]
Wow! That was close ;) , almost got caught with a mistake.:D
Jan Didden
ThomasS
The passive line level x-over causes quite a bit of attenuation but I'll give it a try :)
Nuuk
Then go active! It's not really difficult. If you want to keep with the Les Sage buffer concept, then try these .
Hardly any more work than the buffers and you have your crossover filters as well! ;)
Jan - yes, lucky to corrected that one. I've seen people shot on this forum for lesser mistakes! :D
janneman
quote:
Aha! I was wondering what a Phase-Locked Loop Xtal Oscillator had to do with it....
Jan Didden
Page generated in 0.030874967575073 seconds with 17 queries,
spending 0.00785589 doing MySQL queries and 0.02301908 doing PHP things.
