diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
connect a sub to amp - Click HERE for Original Thread
JSD777
I would like to connect my non-powered sub to my amp but the latter has two speaker out(L & R) can somebody help me to connect it to my single sub. I do know electronic so circuit diagrams are welcome thank you::confused:
sagarverma
is your amp chip amp or discrete.i mean to say that is it bridgeable.
see the instruction manual of amp to determine if its bridgable.
if it is then the two o/ps can be combined to get a single out of twice the power
more on that after your reply
JSD777
Thank you for you reply. Unfortunately the amp i am using has be assemle by myself(hobby kit).the chip is an stk 4392.the schematic diagram given is only a two channel L& R.i was think that it may be possible to design a circuit to bridge the amp.but then i will be using only the left or right of the audio signal.does that not affect the sound.can it be possible to add the L&R signal then bridge the resulting signal.can you help me on how to add the L&R signal to become one. thank you:rolleyes:
sagarverma
show me the amp schematics.
i will advise u on bridging after that.
(dont do it now,wait for further advise::to add the stereo o/p of stereo channel to form a single mono,place two >or= 10k res. from each stereo o/p and join the res. ends together.so now u have a mono system o/p with two wires.u got it!!!!)
richie00boy
You need to make a 'virtual earth' summing amplifier around an op-amp. This is such a simple circuit you can find it anywhere. This will give you a summed left + right. Then you build a unity gain inverter, again an easy to find circuit. This gives your a normal and inverted output to drive your stereo amp to allow you to bridge it.
sagarverma
excuse me richie guy,but the amp in ques. is chipamp.so u cant say abouut its bridging capability until u either see its scheme or see the datasheet.
summing amp for stereo to mono is a bit of a headache when the same can b achieved by a pair of cheap res.
lets see the scheme n then say anything
xplod1236
quote:
Or you can just use a DRV134 from TI.
richie00boy
quote:
The schematic is not important, at least as far as chip amps go where there is very limited scope for implementation.
A pair of resistors will work, but it's far better to use a virtual earth mixer, if you can accept the slight increase in complexity.
quote:
You can, but if you are summing with an op-amp anyway, just use a dual chip and you have a small, neat and cheap solution.
JSD777
Thank you very much for the tip about the two resistors it would really help me.for the schematic diagram i have a print copy so i need to translate it. as it is dont i will sent it to you and thank you again for the great tip(simple and cheap!).so now i have my single out great!
Page generated in 0.030852079391479 seconds with 17 queries,
spending 0.00873351 doing MySQL queries and 0.02211857 doing PHP things.
