| drobert |
hello,
I look for a link to this schematic. Can anybody help me?
drobert |
| kmtang |
Take a look at the JE Lab's line stage. It is very simple but with very good sound.
73
Johnny |
| drobert |
Hello Johny
Thanks a lot your answer, but I think that you misunderstanded me.
I look for a web page where there is this scematic because I need to the descreption for this.
drobert |
| amperex |
| When I view a schematic & parts lists of a design, the entire design is automatically converted to my verbal language of english. In other words, I guess I see the trees in the forest, just not the forest itself. |
| Bandersnatch |
What is unclear?
you have a power supply which will deliver ~240V. The 6SN7 runs its heaters on AC. It has ~6kOhm output Z( excepting where the coupling cap takes over and dominates at lower frequency ).
You should be able to get it working almost anything which is even close to what is described on that schematic.
I'd suggest a higher B+, and double the plate load resistor. 32-34kOhm is a nice load line when B+ is ~440VDC. Drop 250 of those volts across the plate load, for about 6-8 mA.
cheers,
Douglas |
