diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Subwoofer Kits In Australia - Click HERE for Original Thread
sml_nail
Just wondering if there are other stores simlar to Parts Express that will ship to Australia but provide a cheaper shipping option?
All of the local options to me such as Jaycar, Advance AE etc all seem to be fairly expensive in comparison.
I am looking for a decent 12" woofer such as a Shiva or Dayton along with a decent plate amp.
Anyone have any suggestions?
Collo
I'm also in Newcastle and have built a few DIY subs using the Jaycar gear. Give me a yell if you want to hook up....
Collo
rick57
Toys4Boys.com.au seem good for subwoofer amps
http://stores.ebay.com.au/toys4boys...storeviewQQtZkm
shame there isn't an equivalent for drivers
Helpful Melbourne diyaudio-er Paul Spencer may know - please post here if you find one:)
fury
There's also the Loud Speaker Kit who have sub kits.
wintermute
have a look at WES ---> http://www.wagner.net.au/pae/Ventura/XLS1000.htm
you will need to ring them for pricing though. Note I haven't seen or heard one of these.
and the drivers http://www.wagner.net.au/pae/Data.htm
Tony.
rick57
Loud Speaker Kit, aka:
www.essentialaudio.com.au/
. . have almost no info on driver quality.
Amongst WES’s Peerless range ~
www.wagner.net.au/pae/Ventura/Peerless.htm
the XLS are best for deep bass in small boxes.
Otherwise the CSX is very good in a 45 odd litre box, for less money.
f4ier
By kit I'm assuming you'd like a ready-to-assemble sub, complete with pre-cut MDF, which is heavy and expensive to ship.
All you'll really need to have shipped is the driver unit. Acoustic Concepts (in Melbourne) will ship you a Shiva for only AU$17 last I checked. AC might even have kits or completed subs at a reasonable shipping price. AC also sells Redgum and Hypex plate amps.
JE's 12" CS2228 driver unit isn't bad at all especially at its current sale price and they've got a Newcastle branch. (Published specs are all wrong though). JE's plate amps are the same ones PE sells.
A decent jigsaw is absolute minimum must-have for a sub project and they're quite affordable. If carpentry is the problem, well... Surely someone can help out with the cutting part. (Collo seems to be interested in helping you out).
Good luck :)
rick57
f4ier
> JE's 12" CS2228 driver unit isn't bad at all especially at its current sale price . Published specs are all wrong though.
Is JE = Jaycar?
Where can we get the right specs – have you tested some?
Cheers
sml_nail
Thanks will contact Accoustic Concepts to see how I go.
A kit would be nice but given the price of the LSK or other kits the full DIY (or DIY with some help from others) sounds like the way to go.
I am happy to just buy precut MDF from Bunnings etc I just want to make sure I end up with a decent sounding product.
That Jaycar driver sounds interesting. Will performance be similar to say the Adire Shiva? I after something thats going to be used for both music and HT.
f4ier
Perhaps at least one has measured his/her CS2228, but we'd just have to wait for the owner to post the data.
I have one, and its 15" version, which is the best sub JE ever sold (which is also discontinued and no longer available). Should've bought 3 more when they were on sale and being sold out.
Anyway, I haven't felt the need to measure either driver because I'm very happy with my Shiva. The only place I've heard the CS2228 is in a car (so naturally it sounded bassy). The 15" version sounds close to a Shiva, but the latter goes deeper and cleaner.
The 15" sub was in a smaller vented-box at Fb=30Hz (shop demo sub) whereas my Shiva is in an EBS alignment at Fb=16Hz... Quite a difference that's why. Having heard both at equal high excursions I can say the Shiva goes cleaner indeed.
Short of requesting JE send one for Dumax testing, which is pointless now anyway, we can only go by pole plate thickness. CS2228 has a thicker pole plate compared to the 15" version, so I'd say the former goes cleaner, but the latter would go louder.
In terms of raw driver performance -- no EQ, enclosure etc. -- the Shiva goes deeper and cleaner simply because it is made for home subwoofer duty. Both JE subs were made for the car audio market, which would explain their relatively higher cutoff frequency (and unconfirmed linear Xmax).
Bottom line... Go for a Shiva -- tried and tested by many.
Regardless of which driver you'll go for, make sure your listening room is nice and solid. Concrete or brick walls compared to something of less rigid and dense material makes a night and day difference in bass reproduction. And hope that you've got good room acoustics.
Cheers :)
Isaac
rick57
f4ier
Is JE = Jaycar??
Shiva is good, but needs a biggish box.
The XLS I believe works better in a small box.
rick57
Anyone know any good local souces of plate amps?
A friend wants one that allows you to run "satellites" off the crossovers, from speaker outs on the plate amp.
Amongst the Hypex plate amps from John Woodhead at Acoustic Concepts,m only the more expensive models have this option.
There's the Australian ebay shop Toys4Boyshttp://search.stores.ebay.com.au/search/search.dll?query=subwoofer+amps&srchdesc=y&sid=95211850&store=toys4boys*com*au&colorid=-1&fp=0&st=2&fsoo=1&fsop=1&submit=Search
. . but again a bit dearer
Jaycar has now stopped selling them.
Target price about $150.
f4ier
rick57, yes.
AU$150 can probably buy a 2nd-hand quality plate amp.
Which ones has JE stopped selling? All models haven't been discontinued last I checked.
For a non-critical setup this is probably ok.
rick57
Jaycar Melbourne told me this two days ago, I thought all.
Though the website shows there staff was wrong.
There's a gap from 60 watts into 8 ohms to 150 watts at more than double the price.
"satellites" off the crossovers - a basic approach
Where have you seen 2nd-hand plate amps? Trading Post?
paulspencer
Unfortunately there isn't anything here that compares well to places like Parts Express.
The XLS is great value here in Australia.
I wouldn't buy a driver like the Shiva anymore. It's a bit out of date now. There are so many sub drivers coming into the market now that are superior.
Often you can get drivers cheaper from overseas, even when shipping is factored in. I purchased my AV12s for just $20 more than it would have cost me to get the Shiva from here.
Regarding plate amps, I prefer to use a PA power amp and get a filter kit like the one you can get from Jaycar cheap. Plate amps often are lacking in their choice of filters, often have boost to be removed and neglect rumble filters! :smash:
Jaycar have cheap sub drivers (and some that are not so cheap), but when I listened to them next to the JV60 kit (on which my mains are based), they sounded terrible!
I believe you can get the TC sounds TC2+ for an attractive price shipped, I know a guy who got 4 of them for about $260 each.
Cloth Ears
I haven't seen a good plate amp for $150 (Aus), yet. The ones that Jaycar were selling had a nasty bump in response at about 30Hz and were more expensive.
I was going to get a Rythmik Audio plate from the US (I think they were $199US+postage). They've got some good options for your high=pass filter. Then I decided on a Behringer A500 from Brisbane Sound Group. $287AUS, including postage, brand new. 160W (stereo) into 8ohms, or 500W (bridged) into 8ohms. But then I've already got the crossover before I hit the amp so that's probably not what you're looking for.
f4ier
rick57, yes, and the occasional 2nd-hand ones at ebay. But while your friend waits for one to pop up, why not save up some more and get a brand new one, or one that's on sale? Occasionally Acoustic Concepts products go on sale. Christmass is coming, so...
Yep :bawling:
You got your AV12s at the pre-order price, right, how much? Lucky! But at US$150 (about AU$200) each at the moment, it's hard to pass up. How much would shipping cost? Couldn't find any shipping information in AE's store. For how many weeks did you have to wait for the goods and is it true that customs has lowered the taxable amount of goods to AU$250? Is it just 10% tax?
Worth considering, sml_nail.
I remember Ascendant Audio were selling out their discontinued line of XBL^2 subwoofers really cheap. Wonder if they've still got some more. (If only I have some spare $$$; my recent change of address took a lot ouf of my pocket.)
All of JE's plate amps have +6dB @ 30Hz, same ones as PE sells, but PE also sell non-EQed ones. I don't like rumble filters... I've no regard for my subs nor my neighbour's paintings and decor :D
I remember seeing one commercial sub, in an old issue of the Australian Hi-Fi magazine, which uses the JE 12" Carbon Fibre driver unit. What was the designer thinking!? That's why I recommend the CS2228/CS2350 if someone really wants one from JE.
paulspencer
Cloth Ears .... warning, will robinson, warning!!!
Don't buy amps from the US. They have reliability issues when used here. When I spoke to a guy from the Australia Behringer Service centre about buying from the US he said "you're mad!" Even if they can switch to the necessary voltage, apparently they are more prone to failing. Don't do it!
Isaac, yes I got it on pre-order, however, at certain times you can get them cheaper depending on exchange rates, which I think are more favourable now. I got it surface mail, but I know a guy in Tassie who got the TC2+ (which is like a lower distortion version with a bit less xmax and different parameters) - he got them for about $260 each and he went for a more expensive shipping option as he wasn't prepared to wait for weeks!
To calculate cost:
$USD + 5% (customs)
Add postage (www.usps.com)
Convert currency with an online calculator (typical x 1.3)
Rough guess is that a $150 driver gets here for about $260 or so ...
Ascendant audio won't ship here. I sent them an email asking why (I wasn't impressed). No response. Obviously they don't think there is a market outside the US worth serving. Maybe if more will make some noise they might change their minds.
Cloth Ears
quote:
Paul,
Point well taken. I think Brian Ding's trying to build up a reputation for his plate amps. So when he says he'll provide a 50Hz/240v version, I would probably believe him. The only reason he's not selling here is that he doesn't have a distributor.
That said, as I mentioned, I've got an active x-over, plus an equaliser with a sub feed, so I have no need of a plate amp. Interesting you mentioned the Behringer Service Centre, have you met anyone yet who has used the new A-500? I'm planning on getting one for my next payday (unless Xcellent wins the Cox Plate:-).
paulspencer
When Brian does have one, I must admit his servo kit is VERY interesting! What I'd really like is a version you can use with a power amp!
I'm also looking at getting that amp and no I don't know anyone who is using it (although have heard postings from one guy on here who has). I'm actually looking for others interested in a group buy for some Behringer stuff. Last year around this time I found the best price for Behringer stuff was at the distributor recommended by the guy at the service centre as "a big discounter." This year I'm going to try for even better prices with a group buy. Interested?
Since you are in Melbourne, shipping wouldn't be needed.
Shoot me an email if interested. I'm looking at getting the A500 and Ultradrive (although I'm told to expect a wait for that). Even if we get just a few interested, it puts us in a much better position to get good prices.
fury
I too have been looking at the Behringer gear recently, and am interested in the A500 amp... I'm also in Melb too, so if anything goes ahead with a group buy, send me an email :)
I currently have a JE 350wrms Sub amp module, and although it has plenty of power, the xover really isnt substantial enough. For some reason I seem to get a boost around 100hz, and the bass boost around 35hz probably isnt necessary.
I have to finish up my sub box before I do any further testing...
A cheap alternative could be to buy one of the DSE 2 channel amps, and with slight modifications, these can be bridged.
They have been tested to put out 125wrms @ 1%thd @ 4ohm(cleaner at 120wrms obviously), so would put out in excess of 200wrms into 8 ohm bridged.
Might be worth considering, as these rrp for $199 aud but have been known to be on special for as little as $129 aud.
Good luck with it.
mike.e
Those are cheap! not sold in NZ.
If they are rated only for 8ohm not 4ohm,when you bridge them then they wont operate well as each amp only sees half the load impedence ie 4ohm. And then youd need a seperate sub filter.
I dont trust my jaycar '350w' amp and want to upgrade to an EP1500 or similar:smash:
paulspencer
Those Behringer amps are hard to beat.
Those DSE amps are rated for 8 ohms. You would be mad to try to bridge a pair of them. Firstly it would cost more than a single A500, and secondly the power supply would not be adequate to support bridging. With some modifications you could bridge each amp to mono then use two of them to get 2 channels. But in so doing you are removing warranty also. Why not just spend a few more bucks and get what you want?
rick57
Paul
I know zilch about the quality of the PS in the A500 - what do we know about the quality of the PS in the A500? On the web?
Cheers
paulspencer
Richard,
I don't believe there is really that much to power supply "quality" except that it should be able to supply the maximum rated power of the amp and deliver sufficient current to do so into the impedance load presented by the speakers. So basically a question of it being big enough. All I have to go on in this regard is a review I've seen of the Europower amps, mine in particular, in which it measured slightly higher than the standard Behringer specs, which would suggest the power supply was adequate.
That said, adequacy of the power supply with a 230w amp used to drive mains in a home environment is not much of an issue. Even if it didn't manage to get above 200w, the difference in output would be minimal.
I think talking about adequacy of a power supply is more of an issue when you are talking about a moderate power amp like a Rotel or a Nad in comparison to a mass market product like a Pioneer. A 40w Nad might perform better than an 80w pioneer due to conservative ratings and a generous power supply. I still have a NAD power amp which has 6db of dynamic headroom. I have never seen any other amp with that much dynamic headroom in their specs!
Considering how much power is on offer here at such a low price, I suppose its wise to avoid counting on every last little bit of power here. I think this is a good idea anyway, plenty of headroom ensures a system won't clip, keeping speakers safe from damage and ears free from fatigue!
This amp isn't the first amp I think of when it comes to driving a sub. I'd prefer to have more power for a sub if you are using a typical sub with a 12" high excursion driver. I wouldn't use it for anything beyond mains or for woofers, although there will be some who will find it a good buy for certain subwoofer applications.
Cloth Ears
Richard/Paul,
I've sent the question off to Behringer, so hopefully we'll find out what's in the power supply in the next couple of days.
As the unit is designed for professional use, I'd expect the power supply to be adequate for bridged usage. Also, I've found that Behringers' specs are generally conservative.
rick57
Paul
Why do you suggest it’s ok for woofers (maybe down to 40 Hz), but have reservations for subwoofers (eg down one more octave to about 20 Hz)?
Factors in amp PS sound quality include:
- Dependent on drivers being driven - ability to handle low impedance
- Dependent on drivers, above say 80 Hz, excursion may be limited by the amp’s maximum current capability. I don’t know how this can judged by specs.
- Capacitance enough for the drivers, material (amount of bass & general energy) and volume.
An amp can be over specs on watts, but be below par on any of the above. I think there are other factors, but can’t currently recall.
paulspencer
Nothing to do with the bandwidth, just that I think more power is most often preferable with high excursion subwoofers. I once heard a comparison of a Tempest sealed subwoofer, one which is not extreme in its power requirement. Powered by a plate amp (I think it had 240w or perhaps 350) it sounded tame in comparison to a Crown K1 with IIRc 500w - there was a clear difference with authority even when played at the same volume. I suspect it may have had to do with dynamic power capability. The difference was quite a bit more than I expected to be possible.
rick57
Yes I'm aware of that.
Let's hope Behringers's reply allows us to make some assessment of how "big" their PSs are.
rick57
Alas for those outside the US, due to lost packages/no tracking, Parts Express have recently stopped offering economy surface shipping, and will only use airfreight.
I've heard of a recent quote for US$260 worth of drivers to Oz was $US 280 shipping.
rick57
A bit more info:
A well controlled power supply means a low impedance supply, requiring
1. large transformers, with a
2. low resistance secondary winding and
3. possibly large capacitors with high capacitance and
4. low ESR.
It could mean the PSU is well regulated. However an unregulated supply has a definite advantage in the peak vs continuous output power.
The tranny is the final arbitrator as to max continuous power,
Big Cs improve transient power and reduce clipping on peaks. The bigger the capacitors, the longer this transient power can be maintained.
It’s the total package that is important.
Even in a home environment, I suspect you can have lots of power, but run short of sustained transient ability (depending on speaker effiency at the freqency, room size, volume, etc).
The sound quality of the A500 has been compared to a Rotel or Adcom.
Linkwitz has demonstrated that sealed subs need more power at 100 Hz than at 40 Hz.
I think with much music, most energy, need for power and capacitance is about 60-180 Hz. The bottom octave (20 – 40) is used more for soundtrack effects and the 1812 Overture. Electronic dance is I recall about 40 – 100.
A better amp PS will help with most frequencies from 200 Hz down. :dead:
Cheers
Page generated in 0.09001898765564 seconds with 17 queries,
spending 0.01132011 doing MySQL queries and 0.07869887 doing PHP things.
Please support our sponsor.
