diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
opa549 class a - Click HERE for Original Thread
odysseybmx414
anybody try opa549 biased into class A??
sss
how can u bias the chip intu class A?:rolleyes:
the bias is internally set for class ab operation
carlosfm
The same way as you can bias any op-amp.;)
odysseybmx414
how exactly would that be done if im using a +-21v supply? i dont have any transistors so thats out of the picture unless thats the only way to do it. is there any other way? i heard of using a resistor from the neg sup rail to output but i dont know what size etc. any tips?
carlosfm
Search around, I tried it with the LM1875.
Didn't like the results, though...
Yes, you can use high wattage resistors.
sss
quote:
oh , u mean that way , thats not really a class a operation .
anyway all thats gonna do is heat up the poor chip .
carlosfm
Yes, it heats a lot. It's not pure class-A, of course.
If I remember, I biased up to around 500ma.
Hot heatsinks...:hot:
The sound was too smoooooth for my taste, the more the bias the more the smooothness. Then the detail vanished.
It will surely work better (but probably not well) with VERY easy to drive and sensitive speakers, but why bother?
tschrama
no no no no that's a .. well let's say.. less elegant way to do it.. but ...NP has published a few pdf ideas to play around with chipsamps .. one of those ideas was to use 2 power opamp in a balanced config, eg 2x lm3886 , biasing them at some arbitrairy Iq.. so that the work in class A PushPull ...
anybody remember that theads' name?
odysseybmx414
NP?? whats this pdf?
Page generated in 0.025535106658936 seconds with 17 queries,
spending 0.00840712 doing MySQL queries and 0.01712799 doing PHP things.
