| imix500 |
| Hello all, I need a quantity of large electrolytics. Looking for around 450v at around 1800uf but I am flexible. Number needed will depend on price, but more than a couple. Thanks! |
| SmarmyDog |
I have hundreds of 1500uF, 450VDC computer-grade capacitors available. I also have a few hundred 800uF ones. They are all circa late-80's to early-90's. The dozen or so that I re-formed worked just fine.
$5 each for the 800uF, 450VDC ones.
$8 each for the 1500uF, 450VDC ones.
I can fit ten of the 1500uF ones into the $7.70 flat-rate USPS box.
-Casey Walsh |
| Apex Jr |
I have a good quantity of a 4600UF 450V Cornell Dublier
3" dia X 6" Tall at $15.00ea with clamp late date codes
Steve @ Apex Jr. |
| imix500 |
Wow, thanks for the replies guys, didn't really expect to have any luck.
Hey Steve, can I get the part #'s of the caps so I can get specs? You can post or email them. Thanks |
| Apex Jr |
C/D part # 500X462T450DP2B
date code (0019) 19th week of 2000
Steve @ Apex Jr. |
