diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Hot hot ouch - rectifier - Click HERE for Original Thread
Nordic
Ok except for the 2 2VAC windings, my transformer also has a 6VAC one... rated at 1A,
I connected a bridge rectifier to the 6V, and connected the rectifier to a small 12VDC PC fan...wich says something about 0.1A on it...
It all runs nice and quiet due to the low voltage, but the rectifier heats up something mad...
ANY ADVICE?
:confused: :confused: :confused:
djQUAN
you forgot to mention what bridge you are using.
if that's a 35A one, then something is definitely wrong!:D :clown:
Nordic
It says RS405
Looked it up now
4.0 mA single-phase silicon bridge rectifier in 4-pin KBL package. Operational temperature range from -55°C to 150°C, hmmm so maybe this is too small for a 1A winding...
ACD
I shall be hot ;)
You are using a 4 mA bridge to pull a 100 mA fan :D
Nordic
hehehe, luckily it was sitting right infront of the fan...
I have some BZT03C10 diodes... lol whatever they are (looks like little white eggs with a black line... and looks tough... (put on flamesuit).
Maybe I can build a rectifier using these (I have 4)
How do I tell the rating? did see it before but can't find it again.
djQUAN
dont.
what you have is "Silicon Z-Diodes and Transient Voltage Suppressors"
according to http://www.datasheetarchive.com
Nordic
No man don't say that, now i have to wait till monday again...
Would you care to explain why not...? It seems they can handle some 15V and 20A
djQUAN
let's just say what you have is a 10V zener diode.
don't you have rectifier diodes in your junk box? the 1N400X diodes are the most common and you can find them in almost anything electronic.
Nordic
Would the x represent the amperage rateing?
djQUAN
nope. X represents the PIV or peak inverse voltage.
all the 1N400X diodes are 1A.
1=50V
2=100V
3=200V
4=400V
5=600V
6=800V
7=1000V
Page generated in 0.024893045425415 seconds with 17 queries,
spending 0.00777602 doing MySQL queries and 0.01711702 doing PHP things.
Please support our sponsor.
