diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Impedance of... - Click HERE for Original Thread
Sch3mat1c
I need to know the impedance of the network:
- Input (node Vz, impedance Z, current Iz)
- Series inductor L1 (reactance XL1, voltage VL, current Iz)
In series with a parallel tank consisting of:
- Capacitor C (reactance Xc, voltage Vx, current Ic)
- Inductor L2 (reactance XL2, voltage Vx, current IL2)
- Resistor R (resistance R, voltage Vx, current Ir)
So that Iz = vector sum of Ic + IL2 + Ir.
And also, the voltage Vx (on the parallel-resonant tank circuit) in terms of Vz, R, L1, L2 and C.
I think I've got Z right, but I've made two tries at Vx, coming up with similar equations (using the same process....humph, I need more sleep...), neither of which shows proper behavior when R > infinity at resonance (voltage is supposed to rise in proportion to Q!).
Tim
Page generated in 0.015204906463623 seconds with 16 queries,
spending 0.00776792 doing MySQL queries and 0.00743699 doing PHP things.
