| What is the best DIY Interconnect that I coul build? - Click HERE for Original Thread |
| Guijs |
Hello,
What is the best DIY guide to build a RCA Interconnect? Is it possible tu build something as good as a Audioquest Coral, or similar?
Guilherme |
| pinkmouse |
Opinions differ...;)
If you search, you will find plenty of them! |
| haiqu |
I've tried several of Allen's designs and had nothing but improvement over any commercial cable I've tried so far. YMMV of course.
Rob |
| DSP_Geek |
I found interconnects could be improced if one added a 3.3 K (value not critical) resistor at the load end: the sound seemed to be a bit cleaner in the high frequencies. This obviously only works for solid-state stuff, and NOT for phono preamps.
For what it's worth, this was in a high rf noise level environment. |
