| Andypairo |
Hello,
I'm searching for at least 4 pcs of 10000 uF capacitors, voltage rating >=40V, snap-in, to fit my Mauro Penasa Ref Boards.
105°C types preferred.
Can buy but prefer to trade with the components listed in this wiki http://www.diyaudio.com/wiki/index....ge=SP_CS8414_GB
Available to trade also 10uF/400V MKP caps or dual smd to DIP8 adapters with 2*OPA627 installed!!
Cheers
Andrea |
| lgreen |
| I bought some 12,000 uF snap ins at 63VDC from some guy in canada, who ripped me off, by putting them in a small plastic envelope and sent them international to me which banged them up quite a bit. I had to throw out some due to leaking electrolyte. I've got a few that I think are working and don't look damaged. You can have them if you want. |
| joensd |
Hi Andrea,
I´ve got 12 14000uF/50V caps from Kendeil
which are 35.5mm diameter, 51.5mm long, 10mm Snap-in type. (1.40€/piece)
Unfortunately I don´t need anything you´ve listed.
Looking for GC toroids actually (~2*24VAC).
But anyway let me know if they´d work for you.
greets |
| Leeuwarden |
Jens,
Kendeil's for 1 euro and 40 cents????
Sounds like a miracle:bigeyes:
Jan |
| joensd |
To be honest, Jan, I´ve never even heard of Kendeil.
Are they any good?
It only says "Kendeil", "made in italy" and capacitance/voltage-value on the cap.
I´ll probably skip my Aleph3 project so have a few caps to spare plus other things. (Felsic caps, toroids, heatsinks, PCB´s...)
greets |
| Leeuwarden |
Well, as far as I know Kendeil is rated in the top segment.
1, 40 is very cheap, they sell over here for about double that price.
http://www.ae-europe.nl/condensatoren.htm
Link is in dutch, but I think you understand.
I think it is worth while to use them and check how they sound.
Jan |
| Andypairo |
Hello,
thanks for the offers, but the size constraints are somewhat smaller, about 30mm diameter.
Andrea |
| joensd |
30mm diameter for 105° won´t be too easy to find although 85° for a "cold" amp should be fine really.
The 10000uF/40V BC Components 056 series would fit (amongst others) but isn´t 105°-type.(available at Schuro)
Also going down in capacitance shouldn´t hurt really.
There are 4 caps on the board anyway, aren´t there?
greets |
| Andypairo |
105°C types are the preferred choice but also 85°C will fit.
In this moment I use 4700uF but wanted to use the "standard" 10000 uF value.
The board uses 4 caps.
Cheers
Andrea |
