| robselina |
Sorry for what feels like a pretty silly question but I'm having trouble sorcing parts listed for Thorsten's phono pre:
http://www.users.nac.net/markowitzgd/phonopre.html
I'm usually an off the shelf kind of guy, buying mostly from Mouser and Digikey so this is a little higher quality than I'm used to.
Anyway, mouser has some of the Wima MKP4 caps (smaller ones), but not the larger ones required. I can't find 1/2W Holcos, just the 1/4W ones, no idea whater to get the Elna Starget power supply caps and I can't seem to find the philips caps too easily either.
I tried MCM and partsexpress too and I can't seem to muddle it all together quite yet.
Could someone who's built this stateside help me out with some sources?
Thanks,
Rob |
| randytsuch |
Hi
The philips caps are polystyrene
I just bought some styrene caps from these guys
http://www.surplussales.com
You can see if they have the values you need.
They are nos styrenes, not the philips that Thorsten recommended, but I think they will do the trick. Polystyrene is no longer manufactured, so it is hard to find these caps.
For Holco's, you need to make sure they are NOS, as the NOS holco's have non magnetic leads, which sound better. If someone is using Holco's for audio, they use the nos non magnetic ones.
Michael percy has holco's, but not in all values. He also carries Resista resistors, which I like to use. Percy is a good source for parts for diy audio in the US.
I am not sure where to get elna caps, you could use blackgates or nichicons from percy. I like blackgates better, but they are more expensive, and you have to give them time to burn in, at least a couple hundred hours.
Hope this helps.
Randy |
| robselina |
Thanks for your help Randy. I've also managed to source some of the parts from http://www.partsconnexion.com/
Between all these suppliers should have just about everything ordered today!
Now if I could just settle on a PCB board.... |
| randytsuch |
One other thing.
If you do use polystyrene caps, they are very heat sensitive, so you must be carefull when you solder them.
I attach an alligator clip on the lead, between the cap body and the solder joint, which helps suck up the heat, so the cap does not see as much heat when I solder. I also try to solder quickly. When finished, I always make sure the cap is not shorted out with an ohmmeter.
Randy |
| robselina |
| thanks for the tip, I'll go easy on 'em :smash: |
| Jocko Homo |
I may have some 'styrenes around. But I have gone to using Wima FKP types in their place. TAW sells them. At least they will not melt as easily.
Jocko |
| robselina |
| I've managed to source everything except for the 330uF film/electrolytics. I've bought some black gates that will let me get it assembled, but would love to find a film type for that cap if anyone has some.... |
| randytsuch |
Now that it's too late to use, some other advice I forgot to give you before :( .
I am building a similiar circuit, a phono input using fet's, thorsten's version on the l'pacific phono stage, available at the yahoo thunderstone page.
I am using polystyrenes for the RIAA part, and bought a bunch of them. Bought 3x what I needed. Used a cap meter to measure the actuals, so I could match them. I matched them to be very close to each other, and within about 1% of the schematic value.
I also bought matched pairs of fets for my circuit, and I always match resistors, even if they are 1%, I but extra so I can match as close as possible.
Maybe I am just anal, but if the parts are cheap, it makes me feel better to buy extra so I can hand match them. It is one advantage a DIY'er has over mass produced stuff, this would be very expensive to build in production, but my time is "free", so I can do it for my one phono stage.
Randy |
| robselina |
| I had them match pairs within 0.1% for me ;) They only charge $1 for their time, and I figure that's closer than I'll get with 5x quantities.... |
| randytsuch |
| quote: | Originally posted by robselina
Where did you end up buying them from?
Randy |
| robselina |
| quote: | Originally posted by randytsuch
Randy |
Parts Connexion. |
| buddha |
| - O/T - randy - could you e-mail me please? I found an old thread of yours where you got a CD of Toshiba service manuals. I'd like to know which other models were on the disc. Cheers. |
