diyAudio.com diyAudio Forums Archive > Top > Source > Digital
What caps for Analog PS of R2R DAC? - Click HERE for Original Thread
quantran
People usually use Sanyo OSCON for digital components. However I think such cap may not be suitable for the analog PS pin of R2R DAC chips. Any recommendations?
Black Heart
Guess it depends a lot on your audio philosophy and preferences. On my PCM1704 based DAC I only use polypropylene and paper/epoxy caps for all the power in the analog section, and that includes all power and reference conections to the D/A convertors. Tried a lot of combinations including the data sheet suggestions of big value electrolytics, but they just gave it a harsh sound. So I went back to bare bones with just the minimum amount of high quality caps needed for good performance. The power supply is detailed in the shunt reg thread at http://www.diyaudio.com/forums/show...1873#post711873
Get rid of al the electrolytics and you'll be happier :)
quantran
I agree with your point on electrolytic cap. I tried a few electrolytic caps inlcuding ELNA cerafine in the I/V stage (OPA2134). All of them make the sound grainy so I only use 0.1 uF WIMA MKP10 as bypass caps. Surprise, the bass is still full.
I will try some larger film caps at the Va+ and Va- pin of the DAC chip (AD1865N). Only problem is that they are physically quite big to fit.
Page generated in 0.01869010925293 seconds with 17 queries,
spending 0.00711775 doing MySQL queries and 0.01157236 doing PHP things.
