diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Highest sub xover point for music - Click HERE for Original Thread
regal
I am building as pair of fullrange speaers, I want to limit as much bass to them as possible.
If I built two subs (one under each speaker) and fed them a mono signal how high can I go with the crossover.
If I was sending a stereo signal I am sure I could go as high as the subs will play but with a mono signal I am unsure.
mwmkravchenko
I'm a little confused as to what you want to do. Are you asking how high up in frequency a sub can play before you can hear where it is coming from?
Mark
cowanrg
mwmkravchenko,
i think thats exactly what he's asking.
ive heard that around 100hz - 120hz is where it starts being directional.
mwmkravchenko
I would say around 80 hz for this reason.
If that is your X-over point it is the beginning of the decline in the high end of the sub-woofer. It will only be attenuated by the slope that you have provided. Typically the slope is 2nd ordr or 12 db/octave. That means that at 160 hz it will be roughly half as loud as at the X-over point, and at 320 hz it will be 1/4 as loud. Ideally you would want a fourth order slope or 24 db/ octave . That would put it 1/4 as loud at 160 hz. This is enough to be an effective low end to high end crossover.
Mark
Page generated in 0.019411087036133 seconds with 16 queries,
spending 0.00857568 doing MySQL queries and 0.01083541 doing PHP things.
