diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
isobaric resonator? - Click HERE for Original Thread
tade
I think isobaric means to abutt to drivers cone to cone and haveing them move together? what if you moved the drivers apart with an air volume. this air volume would couple with the drivers at its resonance and damp everywhere else? I think of it as holding a fishtank full of water and sloshing it around. has this design ever been studied?
thanks
richie00boy
An air gap/chamber between the two drivers can add to the effective mass property of the cone. You'll have to search for your own references, I wouldn't imagine it's that easy to pull off in practice compared to what theory predicts.
SY
It's not only been studied, it's been done commercially many times. See, for example, the Dynaudio DA500 from the '70s and the more recent Consequence.
tade
cool! what keywords should i search when i do some research?
thanks a bunch.
johninCR
The Decware Housewrecker does exactly that in a 6th order bandpass alignment. The isobarik chamber in the middle smooths the response verses a typical 6th order bandpass.
tade
facinating!
mike.e
isobaric, -3dB sensitivity,half box requirement. Good for lots of cheap woofers.
Page generated in 0.032730102539062 seconds with 16 queries,
spending 0.01293945 doing MySQL queries and 0.01979065 doing PHP things.
